ESP Replacement: LM/Fuel Injector Issues?
vegenativ
Post07-11-2006, 15:59    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
Since I'm not entirely sure what kind of problem I'm having, please excuse me if I've ended up in the wrong section.
I replaced my 11mm ESP from an ALH engine in my AFN today with a 10mm one, because the old one was probably defective; it could no longer be adjusted for injection timing, after 450 km since being purchased as new here from this forum icon_sad.gif.
"With the new fuel pump, the car starts well, and there's no black smoke except during significant load changes. The idle speed control now has a total tolerance of 0.3 (engine is new)."
However, I'm experiencing a problem where the engine seems to be running in a limp mode; approximately a maximum of 15mg of fuel is being injected per revolution, and the maximum RPM is 3,000.
The air mass readings are also completely off; when I accelerate, they drop from 385 mg/stroke to just under 210 at 850 target. It's hard for me to believe that the air mass sensor has suddenly and completely failed. Since I tested the system several times during assembly with some connectors partially disconnected, resulting in error messages that I have since cleared, I suspect that the engine control unit (ECU) might still be in a limp mode despite the clear error memory. In that case, the poor air mass readings might just be a consequence of the insufficient fuel injection.
Is it fundamentally possible, and how can I reset the MSG?
Thank you. Please forgive any unintentional mistakes. Brainstorming is welcome.
P.S.: The diode test is coming up now, but I don't really believe in it.
Translated on 02-09-2026, 7:03.
Post07-11-2006, 16:00    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
Just read the error memory. There will also be information about the limp-home mode.
The air mass is far too low. Did someone forget a cleaning cloth in the engine?
Translated on 02-09-2026, 7:05.
vegenativ
Post07-11-2006, 16:05    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
The error memory remained empty after being cleared.
"The cleaning cloth incident actually happened, but as I mentioned, the car has driven 450 km with the 11mm pump, and it had acceptable performance, as far as I was willing to tolerate during the initial break-in period. Nothing else was changed besides the pump replacement."
Translated on 02-09-2026, 7:06.
Post07-11-2006, 16:57    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
I suspect you forgot to pick up a cleaning cloth somewhere icon_cool.gif.
Translated on 02-09-2026, 7:07.
vegenativ
Post07-11-2006, 17:09    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
Do you really think that a simple cloth wouldn't affect anything at a speed of 140 km/h over a distance of 400 km, and that it would only cause problems when the ESP system is in a vulnerable position?
It would also surprise me if it shows a significantly higher air mass reading than the specified value when idling.
vegenativ
Post07-11-2006, 17:50    Subject: ESP Replacement: LM/Fuel Injector Issues? Quote
Okay, Rainer isn't messing with me.
I installed a diode, and now I'm getting excessive black smoke when I accelerate.
I then disconnected the charge air hose directly at the intake manifold, and afterwards, the engine responded much better to acceleration. I still can hardly believe I forgot a cloth again, so I'd like to know if a turbocharger can fundamentally be so defective that it restricts the airflow to such an extent? In principle, the resistance shouldn't be enough, even with a stationary impeller. And if it can, can this happen without any noise?
Thank you very much.
Translated on 02-09-2026, 7:08.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reduce MSW: Disassemble or Lower Injection Amount On-Board Diagnostics (OBD)
No new posts A6 Automatic Transmission Problems: Shifting Issues? On-Board Diagnostics (OBD)
No new posts GSK Shares Traded: Analysis & Trends Diesel Engine Technology
No new posts Cylinder Head AFN Replacement. Diesel Engine Technology
