The Passat has two different braking systems, which can be easily distinguished by looking at the rear brake discs: solid discs or internally ventilated discs.
What type of engine does the 170 hp TDI have?
The information I have is older than the engine itself, and its power output of 125 kW falls exactly in the no-man's-land between the performance limits of the two systems.
