Remove license plate
Markus H.
Post21-12-2002, 14:32    Subject: Remove license plate Quote
How do you remove the rear license plate holder located between the taillights?
I mean the version where the sign itself is embedded in a plastic frame.
Since I'm not sure whether it's screwed onto the trunk lid, just clipped on, or fastened with retaining clips, I'd rather ask to be sure.
If you start fiddling with something without knowing what you're doing, you might break it.
Sure, here's the translation:
'This is the Audi 100 C4.'
Thank you.
Translated on 04-07-2026, 22:21.
Markus H.
Post21-12-2002, 16:50    Subject: DONE! Quote
You pull off the front, outer frame; that's where the license plate is located.
The mounting bracket behind it is attached to the trunk with 2 screws.
Translated on 04-07-2026, 22:22.
No new posts [Poll] License plate holders Diesel Engine Technology
No new posts Remove the intake manifold from the AEL engine Diesel Engine Technology
No new posts Remove Wheel Arch Rubber Parts? Transmission, Chassis, Body & Interior
No new posts VW Passat Brake Pad Replacement & Door Panel Removal Transmission, Chassis, Body & Interior
