Extremwert der Leerlaufruheregelung auf einem Zyl. vom AFB!? | Posts 16+
Go to page: Previous  1, 2
Zak1976
Karma: +0 / -1   Thank you, like it!
Post20-11-2006, 22:45    Subject: Quote
Here's the translation:
"I have a quick question about the tip of adding large amounts of motor oil to diesel fuel. Wouldn't that be dangerous for the catalytic converter (or, in newer TDIs, the DPF)?"
Fährt mit Golf 3 TDI Umbau (von AFN auf ARL)
Translated on 17-07-2026, 16:50.
Back to top Profile PM Email
bastion
Karma: +6 / -1   Thank you, like it!
Post21-11-2006, 11:05    Subject: Quote
"The VP37 diesel engine won't be significantly affected. The VP44, PD (common rail), and CR (common rail) engines, with or without DPF (diesel particulate filter), will not be impacted at all. However, CR engines can sometimes experience issues if they are fueled with low-quality regular diesel. Furthermore, you likely won't pass the emissions test (ASU) with a Euro 4 standard."
A4 Avant 08/01 AWX 05/08-
christians
Post21-11-2006, 12:36    Subject: Quote
Engine oil, specifically the type for four-stroke engines, should not be used due to its high ash content. If you want to make it easier on your pump and potentially extend its lifespan, you can add two-stroke oil in a ratio of approximately 1:200.
Gruß Christian
Translated on 17-07-2026, 16:51.
Zak1976
Post21-11-2006, 22:23    Subject: Quote
It's not that I intended to do it, but I remember this happening with older Mercedes-Benz diesel engines, when gasoline was accidentally put in the tank.
No new posts Idle Speed Control Valve 38mm Diesel Engine Technology
No new posts Idle speed control Diesel Engine Technology
No new posts AVF Idle Speed Control - Cylinder 3 On-Board Diagnostics (OBD)
No new posts Idling Oxygen Sensor: Causes of -2.4mg/H Reading Diesel Engine Technology
