Pump-nozzle
TomTDI
Post16-12-2002, 9:37    Subject: Pump-nozzle Quote
Does the 10Cent tuning also work with PD engines? I haven't found any information or posts about it. If it does, I'd like to try it out. I have a 2001 Passat with a 96kW PD engine.
Post16-12-2002, 11:01    Subject: Pump-nozzle Quote
... concise and to the point --- NO.
It only works with VP engines!
REDBULL
Post19-12-2002, 21:47    Subject: Not quite right... Quote
I drive a car with a 150 horsepower engine and a 10-cent tuning modification. Torque and responsiveness have significantly improved!
Andre.
Michael II
Post19-12-2002, 22:30    Subject: Pump-nozzle Quote
How did you do that?
Tschüss
Michael II
REDBULL
Post20-12-2002, 0:30    Subject: simple... Quote
...I disconnected the temperature sensor plug. I added a resistor to pins 1 and 2. Done. The problem is that I relied on a tip regarding the size of the resistor.
Post20-12-2002, 8:07    Subject: Re: simple... Quote
REDBULL wrote:
...removed the plug from the temperature sensor. I added a resistor to pins 1 and 2. Done. The problem is that I relied on a tip regarding the size of the resistor.
Wow, and that's happening at ALR. If your fuel tank melts, have fun!
Are you absolutely sure about pins 1 and 2?
In the AXR system, pin 1+2 is the signal for the display, and pin 3+4 is for the control unit. To achieve the desired result, the resistance should be applied at the STG (Schweißtransformatorgerät).
REDBULL
Post20-12-2002, 14:11    Subject: Pump-nozzle Quote
The connector for the fuel temperature sensor only has 2 pins that can be bridged using a resistor.
suggermilk
Post20-12-2002, 14:20    Subject: Pump-nozzle Quote
I'm also interested in learning more about tuning for the PD (presumably referring to a specific device or system).
Will I leave the plug unplugged, or should I connect the cable in a loop?
Which pins does it connect to?
What should the optimal resistance value be?
Does a switch need to be installed here for the 10-cent tuning?
'How much more power does this tuning provide for a 130 HP PD engine?'
suggermilk
Post23-12-2002, 3:26    Subject: Pump-nozzle Quote
@bertil, could you please specify the pinout of this connector? Specifically, which terminals should I connect the resistor to?
Does the plug stay connected?
Of course, this also applies to everyone.
and all other electronics professionals.
I understand that this tuning might come with certain problems, but honestly, it's a company car, so I don't really care. I just want it to be relatively inexpensive.
Has anyone ever measured the electrical characteristics of an analog common rail injection system and knows how it's constructed?
Perhaps someone has a small circuit diagram.
PLEASE PLEASE
I think this might interest a lot of people.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA für Pumpe Düse (AJM) Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
No new posts TDI Golf 4: Convert to Pump Duse System Diesel Engine Technology
No new posts Golf 4 Performance Issues: 110 HP Pump Denoise Diesel Engine Technology
