rash
15-12-2006, 13:55 Subject: 1Z Engine Problems: Loss of Power, Cold Start, Data |
I've been reading this forum for a year now, and I'm having a problem that I've done a lot of research on, but I still have a few questions.
I have a Golf TDI 1Z, manufactured in 1996, with 260,000 kilometers on the odometer.
Recently, it experienced a sudden drop in performance under full load and could only manage a speed of 150 km/h on the track.
Everything was normal again on the way home.
Error code read: 00575 Control difference...
Error memory cleared.
"This morning, it happened twice: after driving about 500 meters, when I had given the car full throttle in second or third gear, and then released the accelerator, the car started to idle roughly (like a tractor) and only reluctantly responded to further acceleration. After a few seconds, it ran normally again."
The car always starts without any problems.
Error codes read: No errors found.
All the measured values were within the tolerance range, and the boost pressure values were normal, but one thing is making me suspicious:
"In idle mode, ad group 00 should display similar values in display fields 5 and 6. In my case, display field 5 (intake manifold pressure) shows a '99', while display field 6 (atmospheric pressure) shows a '199'. Display field 5 logically changes when the accelerator is pressed, while display field 6 does not."
Okay, you could potentially point to the N75 (at least intermittently), but that doesn't explain the rumbling sound this morning.
Translated on 21-10-2026, 8:03.
bastion Blaumann
15-12-2006, 19:18 Subject: 1Z Engine Problems: Loss of Power, Cold Start, Data |
What is the exact error message (text)? A4 Limu 07/96 AHU@110PS 192tkm 08/05-05/08
A4 Avant 08/01 AWX 05/08-
Translated on 21-10-2026, 8:06.
rash
15-12-2006, 21:22 Subject: 1Z Engine Problems: Loss of Power, Cold Start, Data |
The error message is not the problem... the 575 has been sufficiently discussed in the forum...
..it's about the data blocks:
"In idle conditions, ad group 00 should display similar values in display fields 5 and 6. In my case, display field 5 (intake manifold pressure) shows a 99, while display field 6 (atmospheric pressure) shows a 199. Display field 5 logically changes when the accelerator is pressed, while display field 6 does not."
...5 and 6 are supposed to be the same, but they are not...
