Comic resonance oscillation at idle
Thomas76
Post28-12-2002, 0:44    Subject: Comic resonance oscillation at idle Quote
Hello!
I'm having the following problem with my 1994 Golf 3 TDI:
There's some kind of resonance vibration when the engine is idling. It's definitely coming from the engine! It sounds like the idle speed is fluctuating. But the tachometer needle is completely steady, so it can't be fluctuations in the engine speed. Do you have any idea what this could be? This vibration is really annoying.
Is a 1Z engine with 210,000 km a good thing?
Thomas.
Michael II
Post28-12-2002, 10:47    Subject: Comic resonance oscillation at idle Quote
Let's read out measurement block 13 from the engine control unit and post the values.
Tschüss
Michael II
Thomas76
Post28-12-2002, 12:10    Subject: Comic resonance oscillation at idle Quote
Hello!
What is measurement block 13?
Does it cost anything at VW if I have the control unit read out?
And what values are stored in this block?
Thomas.
Michael II
Post28-12-2002, 12:22    Subject: Comic resonance oscillation at idle Quote
Normally, that costs something. But you never know...
A list of the measurement data blocks can be found in the error database.
Okay, since you're already at VW, why don't you have the diagnostic trouble codes read?
Tschüss
Michael II
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 2,4 & 2,8 l Motoren, unrunder Leerlauf Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Funny Brake: Troubleshooting & Repair Guide Transmission, Chassis, Body & Interior
No new posts VAG-COM: Strange Values on Audi A4 (1995) On-Board Diagnostics (OBD)
No new posts Komische Verstellstange am Turbo On-Board Diagnostics (OBD)
No new posts Strange Noises During Operation and Load Changes Diesel Engine Technology
