Golf TDI: Can AEL Injectors Fit?
Vtec 1
Post19-07-2005, 22:00    Subject: Golf TDI: Can AEL Injectors Fit? Quote
Here's a brief description of my Golf TDI with 400,000 km and a performance chip.
I have made the following modifications to my Golf TDI, some of which I learned about from this forum.
Exhaust system from front to back, 2.5 inches in diameter; fuel injectors from a 110 HP TDI Sharan; chip tuning from DRS tuning, installed in the oil; sports air filter, not open-style.
Okay, so to my question: I have 5 fuel injectors here from an Audi A6 2.5 TDI AEL with 140 horsepower, and I'm considering installing them.
Does it make a difference, or not?
nachdem ich heute alles an druckschläuchen umgebaut habe von gummi und Plastik auf metall denke ich mal es hält wieder ein wenig , da ich mit einem Ladedruck von 1,7 bar fahre !! NI haven't lied!!
Okay, who can help? Should I assemble it or not?
It would be great if I could get a quick response!!
Sure, here's the translation:
'Thank you in advance!!'
Subject line changed by me (Julian) for clarity of the search function.
Translated on 11-10-2026, 10:37.
kapernaum
Post19-07-2005, 22:08    Subject: Golf TDI: Can AEL Injectors Fit? Quote
Hello from Germany!
I once read that the 2.5L injectors don't fit properly, neither in terms of installation nor spray pattern, in the six-cylinder engine. The key factor for replacing fuel injectors is the cylinder power. How many kilowatts does your engine currently have? And what is the power output of each cylinder in the six-cylinder engine?
Translated on 11-10-2026, 10:39.
Vtec 1
Post19-07-2005, 22:20    Subject: SEO-Optimized: "Best German Translation Services | Online" Quote
I'm talking about an Audi A6 with a 2.5 TDI AEL engine, a 5-cylinder engine!
How did you arrive at the conclusion that it has 6 cylinders?
Translated on 11-10-2026, 10:40.
kapernaum
Post19-07-2005, 22:30    Subject: Golf TDI: Can AEL Injectors Fit? Quote
Ash on my head!
I assumed it was a 6-cylinder engine! As I said, I have no idea about this machine, so my statements should be taken with a grain of salt... Do the injectors fit mechanically? What are their opening pressures, and what about the spray pattern???
What type of fuel injection pump does this engine use?
EDIT: We'll know more soon... 216 injectors would be ideal... however, I believe these injectors were only used in the VW T4 (or the engine).
Translated on 11-10-2026, 10:41.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Larger Injectors: Installation Possible on PD Engines Diesel Engine Technology
No new posts Golf IV ALH: 0.205 Injectors from ASV - Compatibility? Diesel Engine Technology
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
No new posts DSG Conversion for VW Golf IV TDI? Diesel Engine Technology
