reuselkopp Blaumann
19-02-2008, 8:04 Subject: Bosch Part: Gasket & Screw for Quantity Meter Cover |
"This coming weekend, I'd like to clean my volume control knob because it's been acting up. I plan to start by just removing the cover of the volume control and cleaning it that way. Since I assume the seal shouldn't be reused, and it's not that expensive, I want to replace it. I also want to replace the triangular screw with one of the other Torx screws."
Could someone please tell me the Bosch part number for the gasket or the screw? I'd like to know the number beforehand so that the Bosch service center doesn't have to search for it for too long.
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 01-11-2026, 8:19.
Boro Guest
19-02-2008, 8:08 Subject: Bosch Part: Gasket & Screw for Quantity Meter Cover |
Okay, for the seals, there's a repair kit available from Bosch. It includes various or all the seals for the specific pump and costs around €6.50. You just need to tell them which pump it's for, for example, the VP 37.
Translated on 01-11-2026, 8:20.
19-02-2008, 9:47 Subject: Bosch Part: Gasket & Screw for Quantity Meter Cover |
My BOSCH always finds what I'm looking for quickly.
They're faxing me an exploded diagram with numbers labeling the parts, like 1, 2 (not part numbers).
I tell them I need numbers 4,174 and 23, and then I get them.
However, it seems to depend heavily on the individual using the BOSCH computer as to whether they want to and are able to do it.
Translated on 01-11-2026, 8:21.
Profile PM Garage |
reuselkopp Blaumann
20-02-2008, 8:59 Subject: Bosch Part: Gasket & Screw for Quantity Meter Cover |
Hello everyone,
I went to my Bosch service center yesterday. It took the Bosch employee half an hour to find the part numbers, and the result was that I had to pay €14.64 for a set of seals and a screw. What a rip-off!
Let's hope that after the signal box is cleaned, the jolting will stop.
Greetings.
Reuselkopp.
PS: Is the entire fuel injection system (including the circuit board) exposed to diesel? I mean, does diesel immediately come into contact when you remove the cover, or is it only located underneath the circuit board?
Translated on 01-11-2026, 8:22.
Translating... |
[Translating...] all in diesel
Profile PM Garage |
Boro Guest
20-02-2008, 11:08 Subject: Bosch Part: Gasket & Screw for Quantity Meter Cover |
...Well, 14.64 € is still manageable... there are worse things... these sentences were already sold and bought privately on eBay for 30 €...
Translated on 01-11-2026, 8:23.
