Error Code Diagnosis: What's Next?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
MarcR
Post27-07-2005, 7:38    Subject: Error Code Diagnosis: What's Next? Quote
Hello, brothers in spirit.
My mechanic just installed a TDI engine into an Iltis (yes, there are people who do that icon_smile.gif). Of course, there are then some problems here and there. Overall, it runs well, but what do you do when you find something in the error memory? The diagnostic tool decodes the codes into text, but then... Does VW have a table that lists the error code, what the problem might be, and what you can do? Are they included in the '1Z' engine repair manual? As I said, I'm only interested in the engine, but I want to know about all possible errors.
Marc.
Translated on 01-10-2026, 11:10.
Post27-07-2005, 8:22    Subject: Error Code Diagnosis: What's Next? Quote
Try it out.
[Edit Admin]
/viewforum.php?f=3
and the search function.
[/Edit Admin]
Translated on 01-10-2026, 11:11.
Post27-07-2005, 8:58    Subject: Error Code Diagnosis: What's Next? Quote
What is the purpose of this error database?
Simply dial *575 to access the search function.
Translated on 01-10-2026, 11:12.
MarcR
Post27-07-2005, 18:29    Subject: Error Code Diagnosis: What's Next? Quote
Greetings, Rainer
"Yes, that's good, but if I'm stuck somewhere in the middle of nowhere in Peckfitz, far from civilization, I might not necessarily have internet access. Surely there must be a printable list, right?"
Marc.
Translated on 01-10-2026, 11:13.
Post27-07-2005, 18:44    Subject: Error Code Diagnosis: What's Next? Quote
MarcR wrote:
There must be a printable list, right??
Search query: 1Z + Error codes icon_evil.gif
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 Diesel Engine Technology
No new posts Aschemasse falsch ? Und dann ? On-Board Diagnostics (OBD)
No new posts Alternatives to ZMS: Find the Best CMS Solution Diesel Engine Technology
No new posts VTG gets stuck, then releases again. Upload
