Golf IV TDI: Can Engine Control Unit Be Repaired?
nomis
Post31-07-2005, 20:29    Subject: Golf IV TDI: Can Engine Control Unit Be Repaired? Quote
My car has been in the workshop for two weeks icon_sad.gif. It sometimes doesn't respond to the accelerator. The throttle position sensor has already been replaced. Now, my workshop sent the engine control unit for repair. It was returned, and they said it could not be tested or repaired because there is no software for this device. It was used too rarely. Can that be true? After all, the Golf TDI 90 hp is not a rare car.
The VW part number of the device is 038906012GK. I believe it is manufactured by either Bosch or Telefunken.
Who can help me icon_question.gif icon_sad.gif?
Greetings.
Nomis.
Translated on 01-10-2026, 18:22.
Thomas K.
Post01-08-2005, 8:40    Subject: Golf IV TDI: Can Engine Control Unit Be Repaired? Quote
Where was your workshop going to send, or did they send, the engine control unit?
You cannot officially send control units to Volkswagen for inspection or repair. The diagnosis must be made by the workshop itself, using all available tools (diagnostic testers, guided troubleshooting, etc.). If a control unit is found to be defective, the workshop can send it back during the warranty period and receive a new one. If it is outside the warranty period, the workshop can discard it and order a new one for you.
Were you at a VW workshop? If so, they probably ripped you off.
The engine control unit is definitely from Bosch.
A few more details about the car would also be helpful.
What has already been checked?
Engine control units (ECUs) rarely fail.
Translated on 01-10-2026, 18:24.
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine Repair: Tips for VW Golf 4 Diesel Engine Technology
No new posts Engine Control Unit (ECU) Not Responding. On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. A4 B7 ECU Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Login Failed On-Board Diagnostics (OBD)
