Reinforced Clutch 1Z
Blechmann
Post12-08-2005, 21:13    Subject: Reinforced Clutch 1Z Quote
As soon as the installation of the large nozzles is complete, the next problem arises: the clutch.
Question: Is there a heavy-duty clutch available for the 1Z engine (for towing or similar purposes)?
If so, where?
If not, where else can I find affordable couplings?
Translated on 20-10-2026, 14:53.
donalexo
Post12-08-2005, 23:39    Subject: Reinforced Clutch 1Z Quote
Hello Blechmann!
I completely understand your situation. I had a similar experience after my engine rebuild. As soon as the engine started producing proper torque, the clutch started slipping.
I just got a Sachs Performance clutch (Sachs Race Engineering) that can handle approximately 400 Nm of torque and provides a really strong grip.
This clutch is definitely not a special offer. If you're interested, I can give you the part numbers.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 20-10-2026, 14:54.
Blechmann
Post13-08-2005, 14:55    Subject: Reinforced Clutch 1Z Quote
Thank you for the offer, but a Sachs Racing for around €800 is a bit too cheap for me... icon_wink.gif
I remember having a heavy-duty clutch for towing in my old car. Is there something similar available for the 1Z?
What I also wanted to know is: Does the 1Z model have a 228mm or 230mm clutch?
Translated on 20-10-2026, 14:55.
Post15-08-2005, 21:38    Subject: Reinforced Clutch 1Z Quote
I'm currently modifying my VW Bulli...
"I'm planning to increase the power output later anyway, so I might as well install a new clutch at the same time. What's the maximum Nm that the original clutch can handle? The engine I'm installing is a 1Z. Does anyone happen to have a turbocharger or exhaust manifold from an AFN lying around?"
Translated on 20-10-2026, 14:56.
Roadagain
Post16-08-2005, 19:55    Subject: Reinforced Clutch 1Z Quote
I have a Sachs clutch inside.
I think they're called Power Clutch.
They are a bit stronger, suitable for hanging applications and similar uses.
Greetings.
Translated on 20-10-2026, 14:57.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. ALH Engine: Clutch Problems & Solutions Diesel Engine Technology
No new posts AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Diesel Engine Technology
No new posts Coupling Diesel Engine Technology
No new posts LUK Clutch for ALH engine Diesel Engine Technology
