Fuel Injectors VW Golf IV AHU/ALH 90hp
dax_future
Post27-08-2003, 14:06    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
Does anyone know if the fuel injectors for the 90 hp AHU and ALH engines (manual transmission) are the same?
Part number: 038 130 201.
Thank you icon_smile.gif.
Translated on 18-09-2026, 3:27.
Post27-08-2003, 20:34    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
The AHU is still a G3 engine.
ALH 038 130 201 G (the letters are important!!!)
AHU 028 130 201 G
The engines differ in some details.
The nozzles have different part numbers, so they are probably NOT the same!
Translated on 18-09-2026, 3:28.
pandabear
Post04-08-2005, 11:23    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
That's not a reasonable answer. It may be true that the nozzles aren't identical, but that doesn't necessarily mean that a 038 130 201 G nozzle from a G4 engine can be used in a G3 engine instead of a 028 130 201 G. I'd also be interested in knowing the difference.
Paul.
Translated on 18-09-2026, 3:29.
Post04-08-2005, 11:53    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
http://www.bosch-automotive.com/ecat-online
You can at least compare the nozzle opening pressures (which are usually specified).
Translated on 18-09-2026, 3:30.
pandabear
Post04-08-2005, 12:50    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
I have already done that. According to Bosch, they are the same. However, I haven't found any information about whether they differ in their physical design. Possibly the connector is different for the NHG model.
Thank you.
P.
Post04-08-2005, 15:26    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
pandabear wrote:
I have already done that. According to Bosch, they are the same. However, I haven't found out if they differ in terms of design. Possibly the connector is different for the NHG model.
ALH is, as far as I know, a newer generation than AHU.
Since the combustion process is constantly being refined, the combustion chamber geometry, swirl, etc., are also being modified in various ways, and the spray pattern of the injectors is adjusted accordingly.
In short: While the nozzles might physically fit into the "wrong" engine, the engine will likely run with them, but the combustion process will no longer be as intended by the developers.
This essentially voids the vehicle's operating license (even if it doesn't receive any additional power!).
so they are probably NOT the same!!
That's not a reasonable answer. It may be true that the nozzles are not identical ...,
That's exactly what was asked in the first place! So, what's wrong with Martin's answer?
Translated on 18-09-2026, 3:32.
JanT3TDi
Karma: +2 / -2   Thank you, like it!
Post04-08-2005, 16:17    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
"You actually asked about that first! So, what's wrong with Martin's answer?"
@Ulf: Isn't that a bit of a nitpicking argument... we know what was meant by it!
No offense!
jan[/quote]
T3 Multivan mit 1Z aus '95er Passat + Chip, 3H Getriebe + langer 5ter Gang
Translated on 18-09-2026, 3:33.
pandabear
Post04-08-2005, 17:27    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
"Well, this is something. Ulf's answer sounds reasonable; at least there's a justification provided. Whether it's correct is another matter. But it seems logical to me."
Best regards and thank you for your reply.
P.
Translated on 18-09-2026, 3:34.
mullemaus
Post07-08-2005, 19:02    Subject: Fuel Injectors VW Golf IV AHU/ALH 90hp Quote
Whether it's true is another matter. But it sounds logical to me.
She is correct. icon_wink.gif The swirl and piston crown shape (combustion chamber geometry) are optimized for the injector spray pattern.
Translated on 18-09-2026, 3:35.
No new posts Golf 5 / Audi A3 2004 BKC-Motor stirbt ab, startet nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Diesel Injectors: V6 2.5L AFB Engine Repair Diesel Engine Technology
No new posts New fuel injectors for 1Z engine Diesel Engine Technology
No new posts { Diesel Engine Technology
No new posts Fuel Injectors VW Golf IV AHF On-Board Diagnostics (OBD)
