Engine Knock at 2000 RPM
Rudi
Post04-04-2006, 7:24    Subject: Engine Knock at 2000 RPM Quote
I had been experiencing this for some time (the weather was bad, and the discomfort was minimal icon_wink.gif).
Intermittent power steering failures during maneuvering.
This weekend, it was time for another oil change, and wouldn't you know it - the serpentine belt was also due for replacement.
The belt that drives the pump was very loose (the pump could be turned by hand).
Serpentine belt tensioned, operational / maneuvering - no more power steering failures...
but since last night, I've been hearing a 'rattling' (rrrrrrrrrr - sounds like a loose disc on a
(Wave that is not rotating correctly) has been noticed. The noise is speed-dependent.
and reaches a value in the range of 2000 to 2200 rpm.
Two things came to mind spontaneously.
a) The pump's bearing has been damaged due to the loose belt.
b) The belt itself vibrates or flutters at a certain rotational speed.
b) would, of course, be more pleasant (principle of hope icon_rolleyes.gif).
Has anyone else observed similar behavior or noises?
Rudi
Translated on 20-09-2026, 12:41.
Post04-04-2006, 11:09    Subject: Engine Knock at 2000 RPM Quote
Hi.
Have you ever replaced the servo belt?
It's the outer part, so it's super easy to replace.
Perhaps it has "dents" from excessive use and can oscillate on the blank side if the speed matches its natural frequency, leading to resonance.
I can't think of anything else to say.
Not after I had completely disassembled my entire trunk searching for a rattle.
I even tightened the front wheel bearing.
It was the middle mounting point on the right-hand rear seat back that broke!
Translated on 20-09-2026, 12:44.
Rudi
Post04-04-2006, 13:17    Subject: Engine Knock at 2000 RPM Quote
Perhaps it has developed 'dents' from excessive use and can oscillate on the flat side if the speed matches its natural frequency, leading to resonance.
I'm going to go to Grandpa Unger's place now, buy a new belt, and put it on today.
If changing the valve helps - okay; if not, I probably have to replace the pump icon_confused.gif.
Rudi
Translated on 20-09-2026, 12:45.
Rudi
Post05-04-2006, 11:34    Subject: Engine Knock at 2000 RPM Quote
The new belt is installed. The 50km I rode this morning were smooth and trouble-free.
I noticed uneven wear on the flanks of the old belt (in some areas).
stronger than on other occasions) - this could have resulted in fluctuating belt tension.
which then led to the dancing icon_confused.gif.
When I had the belt removed, I then noticed a slight play in the pump shaft icon_sad.gif.
It's working fine so far... but in the medium term, I'll probably have to replace it.
Rudi
Translated on 20-09-2026, 12:47.
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Draft Test / Performance Test 2000-4000 rpm Technical Articles
No new posts What happens at 2000 km? Diesel Engine Technology
No new posts OBD2 Scanner for VW Passat 2000 PD Diesel Engine Technology
No new posts VAG COM and Audi A6 V6 TDI, Model Year 2000 On-Board Diagnostics (OBD)
No new posts AFN Engine Torque Dip at 2000 RPM Diesel Engine Technology
