Fuel Injectors: Different Prices with Needle Lift Control?
Hannes
Post31-08-2002, 19:02    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Today, I had a chance to look at the AKTE price list and found two different prices for the fuel injector with the needle lift adjuster for the Audi A6 C4 2.5 TDI: one for 180 euros and one for 445 euros (it's definitely the one with the needle lift adjuster, and there were also two prices for the other injectors, but I don't remember the exact prices). Is the cheaper price available as a used part, or what's the explanation for the difference?
best regards
Hannes.
Audi Allroad quattro LR, 2004
Audi S6 Avant quattro, 1995
Translated on 01-09-2026, 12:42.
Golfmann
Post01-09-2002, 0:16    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Hello Hannes,
The same thing happened with my Golf. The cheaper option is the exchange price, and the more expensive one is the purchase price.
I also paid around 180 euros.
The Golfman.
Translated on 01-09-2026, 12:43.
Hannes
Post01-09-2002, 10:24    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Thanks for the information!
Is there anywhere else where I can find the needle lift sensor for a cheaper price than at Audi?
Hannes.
Translated on 01-09-2026, 12:44.
Golfmann
Post01-09-2002, 12:32    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Maybe they have something like that at Bosch?
I have no idea.
Have them checked before you buy a new one. There might be something else broken.
The Golfman.
Hannes
Post01-09-2002, 12:51    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Don't think anything else is broken. I've already done the test for the injector control valve (lightly tapping the injector with a hammer at 3000 rpm, and the engine starts to stutter). The airflow sensor, unlike the mass airflow sensor, never seems to break, and I haven't found anything mechanically wrong either. I don't really like going to the VAG workshop anyway, because just opening the hood costs 20 euros there... icon_wink.gif
Hannes.
Translated on 01-09-2026, 12:45.
Post01-09-2002, 20:06    Subject: Car Exhaust Parts Quote
You can identify the replacement parts by the "X" that appears after the version letter (or the number if there is no version letter).
Try to get the parts from Bosch; they also have a replacement parts service and are likely cheaper than the "specialized dealer."
Translated on 01-09-2026, 12:46.
Hannes
Post01-09-2002, 21:01    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Yes, exactly, there was an "X" marked on the AKTE system. Thanks again for the information. I'll probably get the parts from Bosch or Beru, I assume I can find them in any decent auto parts store.
best regards
Hannes.
Translated on 01-09-2026, 12:47.
Hannes
Post02-09-2002, 16:24    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
I have now inquired with Bosch and Beru, and they offer the fuel injector with needle lift sensor at a lower price than Audi (both with a list price of 145 euros).
Does the specified spare part number match the A6 model with the AEL engine?
Bosch: 0986 430 282
Beru: DHD212
Are both parts of equal quality? How about the service and warranty for both parts, is one better than the other?
Hannes.
Translated on 01-09-2026, 12:48.
olli
Karma: +46 / -0   Thank you, like it!
Post02-09-2002, 21:06    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Hi there.
The Bosch part number should be for the AEL engine, while for the AAT engine, it is: [insert part number here].
0 986 430 281
(both with NBF)
I have no idea about Beru.
Olli.
Translated on 01-09-2026, 12:49.
Hannes
Post03-09-2002, 17:00    Subject: Fuel Injectors: Different Prices with Needle Lift Control? Quote
Okay, thanks, so the part numbers match... now I just need to decide which brand to go with.
best regards
Hannes.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Different plug connectors? On-Board Diagnostics (OBD)
No new posts Fuel Injectors (AFN) Prices Diesel Engine Technology
No new posts Spark Plug & Injector Prices Diesel Engine Technology
No new posts Timing Belt Replacement Cost Hamburg Diesel Engine Technology
