Again, 1Z 00575, suction tube pressure too low..
miguelito
Karma: +0 / -1   Thank you, like it!
Post11-08-2005, 1:18    Subject: Again, 1Z 00575, suction tube pressure too low.. Quote
Dear Hobbyists,
...another one, searching for the causes of the mysterious 00575...
The situation is as follows: the actual suction pipe pressure is too low, i.e., in the case of load, it is always several 100 mBar below the target pressure (unfortunately, I don't have a web space where I can store the log for download).
The suction tube length looks neat and airtight, with no oil leakage.
When driving on a highway uphill under heavy load, the - as described here - error case (00575) can always be reproduced very nicely for me. At approximately 140 km/h uphill, the performance drops. My assumption is that the difference between the actual and target suction tube pressure becomes so large (instead of reaching 1850 mbar, only about 1330 are achieved), that the control unit shuts off the suction.
2 possible causes I can imagine: 1. The wastegate is stuck due to being in a partially open state. 2. The pressure sensor is providing incorrect values. Since the car responds and accelerates as usual, I would like to check the pressure sensor. I have a 06/95 Passat with a 1Z engine. Therefore, I assume that this is the engine version where the pressure sensor is integrated in the engine control unit (ECU) and there is a hose running from the ECU to the intake manifold or LLK. Unfortunately, I was unable to locate either the engine ECU or this thin hose, which should branch off from the intake manifold or LLK somewhere. I would like to check if this hose is dirty/misplaced. Can you tell me where to find the hose? And the engine control unit? (Yes, it's embarrassing...)
A pro pos lines: A second, thin line that is NOT for the EGR valve also branches off from the vacuum pump and then goes through a solenoid valve above the intake pipe in the left fender towards the cable/hose bundle at the top of the engine compartment rear wall. It is a thin, white plastic line. Does anyone know what THIS one is for? Apparently, there is still a need for vacuum in some areas.
Inspection and functionality check of the pressure can/wastegate lever are still pending. I will, of course, report the results.
One more question for the experts: In my log, the control valve for the boost pressure has a duty cycle of approximately 90% at idle, and drops to 40% under load. Therefore, I believe that when the desired and actual boost pressures are close together, the ECU will open the wastegate (90% duty cycle -> valve closed, atmospheric pressure, gate opens earlier) to maintain the desired pressure. In the case of load, when the desired and actual pressures continue to diverge, the ECU will attempt to keep the wastegate closed to increase the actual pressure (40% duty cycle -> valve open, atmospheric pressure is mixed with the boost pressure, the gate remains closed at a higher boost pressure). Am I correct? Where are the 1Z Gurus icon_wink.gif?
Thank you,
Greetings from Salzburg
Michael
miguelito
Post11-08-2005, 23:27    Subject: Again, 1Z 00575, suction tube pressure too low.. Translating...
[Translating...]
Nun die Auflösung der Geschichte unter dem Motto:
Sch... Motorabdeckung oder warum man früher keine Diagnoseprogramme brauchte... icon_wink.gif
In den Schaltplänen im Anhang von 'So wirds gemacht' wird die Lokalität der Motor ECU mit ' Wasserkasten rechts' angegeben, also 'raus mit der Kunststoffabdeckung, an der ich zwar schon mal gefummelt hatte, aber bloss auf Verdacht hinauspfriemeln wollte ich da noch nicht. Unter dieser dann Pollenfilter und siehe da: die ECU mit dem mitteldünnen Gewebeschlauch für den Saugrohrdrucksensor. Schlauch verfolgt, der verschwindet unter dieser dämlichen Motorabdeckung - daruntergegriffen und gleich gefühlt: Der ist am Nippel eingerissen und abgeknickt. Also doch Druckgeber / Schlauch schuld, genau wie vermutet...
Ein Kumpel der Mechaniker ist meinte schon mal 'wozu die Abdeckung, die nimmt nur die Sicht auf die Maschine'. Stimmt, ohne der Abdeckung hätte ich den eingerissenen Schlauch sofort gesehen. Und das war's auch schon. Ist-Druck stimmt jetzt lt VAGCOM, die Ladedruckregelung regelt schön bei 1900 mbar ab.
Und die Moral aus der Geschicht: Motorabdeckungen sind doch für was gut: Ich kenn' mich dadurch jetzt leidlich mit VAGCom aus und weiß endlich, wo meine Motor-ECU steckt...
Mag sein, dass dieser Fall für eingefleischte Schrauberlinge trivial ist, denke aber das Beispiel dem einen oder anderen vielleicht doch weiter hilft icon_smile.gif
Michael
Post12-08-2005, 8:00    Subject: Again, 1Z 00575, suction tube pressure too low.. Translating...
[Translating...]
Schön, daß uns Du die Lösung mitteilst.
Obwohl die Sache an sich tatsächlich etwas trivial ist, kann man manchmal gar nicht so blöd denken, wie einem das Leben Stolpersteine (oder Sichthindernisse) hinlegt. Daher ists für mich OK icon_wink.gif
Post12-08-2005, 14:25    Subject: Again, 1Z 00575, suction tube pressure too low.. Translating...
[Translating...]
Ah
Denn die Abdeckung auf dem 1Z im Golf 3 ist so klein, dass man alles sieht icon_smile.gif
Nur der 1Z Passat hatte die grosse Abdeckung wie der AFN.
miguelito
Post16-08-2005, 10:55    Subject: Again, 1Z 00575, suction tube pressure too low.. Translating...
[Translating...]
Hi Ulf,
ja wie gesagt, wollte brav alle Punkte abprüfen, die in zahlreichen Beiträgen dieses wirklich guten Forums beschrieben sind, bevor ich mit Fragen komme. Aber obwohl ich schon lange und nach wie vor gerne schraube, mit der Lokalisierung des Saugrohrdruckgeberanschlusses / ECU war ich kurzfristig überfordert. Ist halt ein weiteres Beispiel wie man mithilfe von VAGCom die Problemursache schön eingrenzen kann.
@dieselmartinViewing profile: dieselmartin - hatte vorher einen IIIer TD, da war der Anschluss für den Saugrohrdruck (beim TD noch direkt an die Betätigungsdose des Wastegate angeschlossen) an so ziemlich der selben Stelle (Knie des Saugrohres knapp vor Mündung in Ansaugkrümmer). Als ich die Abdeckung unten hatte habe ich mich sofort an dieses Bild erinnert und hätte mich in den Hintern beissen können. In dem Fall wäre mir eine kleinere Abeckung auch lieber gewesen...
Trotzdem: Passat for ever!!
LG
Michael
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document error 00575 with full throttle, AKN and AFB engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi, up to 2:00 AM, insufficient heating power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI AHU; 00575 - Intake manifold pressure regulation diff... On-Board Diagnostics (OBD)
No new posts 00575 - Saugrohrdruck Regeldifferenz Diesel Engine Technology
No new posts 00575 - Intake manifold pressure: What could it be? On-Board Diagnostics (OBD)
No new posts Problem Saugrohrdruck Regeldifferenz 00575 gelöst! :) Diesel Engine Technology
