Stalled Car: Troubleshooting & Fixes
AudiV6
Post18-08-2005, 7:38    Subject: Stalled Car: Troubleshooting & Fixes Quote
Hello everyone,
I've been really stressed for the past 8 weeks dealing with issues with my A6 V6 TDI.
Here's the explanation for the delay (post from August 15th).
The surge tank was repeatedly disassembled due to misdiagnosis. Audi!!
In this case, the fuel pump must have been damaged (it's unstable).
Therefore, there was always a fuel shortage error message, and the engine power was reduced. It stopped working!
I wanted to measure the Ohm values on the old, modified sensor, but I didn't get any readings.
Then I wanted to take measurements on the newly installed part. The connector plug was loose!
The plug connector was broken! Also, the warning light was always on.
No workshop followed a logical procedure. Today, I wouldn't remove the trunk floor to measure the sensor; I would measure it directly at the connector on the control unit in the front.
Full tank: 430 ohms; Empty tank: approximately 100 ohms.
I don't trust workshops.
Thank you to Bosch. Excellent contact. After I made an inquiry, the customer service department contacted me by phone.
I also had a pleasant contact with VDO. They manufacture the pre-charging unit.
The Audi hotline only told me to contact my local Audi dealer.
I've never been a professional mechanic; I always just considered it a hobby.
It makes me wonder how someone can sometimes achieve more than the professionals.
Best regards, Willi.
Translated on 01-10-2026, 4:53.
Georg-TDI
Post18-08-2005, 9:07    Subject: Stalled Car: Troubleshooting & Fixes Quote
Good news!
So, out of necessity, you ended up becoming a mechanic after all...
But why a new topic?
I would have preferred if you had posted the solution in the first place.
Translated on 01-10-2026, 4:56.
AudiV6
Post19-08-2005, 15:06    Subject: SEO: Best Practices for Website Optimization Quote
Thank you for the tip, I'm a beginner!
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Emergency mode error code 0519 -> resolved, but why? On-Board Diagnostics (OBD)
No new posts Stehengeblieben !! On-Board Diagnostics (OBD)
No new posts water-cooled AGR - why? Diesel Engine Technology
No new posts Nur 6 Injektoren pro CR-SG - warum?? Diesel Engine Technology
