Engine Misfire: 1Z Won't Accelerate
Lagebernd
Post27-08-2005, 20:44    Subject: Engine Misfire: 1Z Won't Accelerate Quote
My Audi 80 B4 1.9 TDi is giving me trouble. Right after starting, it revs up to a high RPM (around 25 seconds) before the engine control unit cuts it off (limp mode?). I had tuning chips installed before and wanted to go back to the 'standard' ones. Also, the magnetic valve for the boost pressure regulation is making a very loud rattling noise. What happened here? Is the engine control unit broken? I urgently need help!
Translated on 25-09-2026, 14:07.
Post29-08-2005, 7:11    Subject: Engine Misfire: 1Z Won't Accelerate Quote
I had tuning chips installed before, and I wanted to go back to using the "normal" ones.
So, the problem only started occurring after reverting to the standard chips?
Then something probably went wrong (broke?).
Does the engine still behave normally with the tuning chips installed?
What does the error memory say?
Translated on 25-09-2026, 14:08.
Lagebernd
Post29-08-2005, 15:59    Subject: Upgrade to Standard Chips Quote
Hello Ulf!
That's the problem, I installed those replacement chips, and then the problem started.
I've checked everything, but I haven't found anything. My notebook is currently away from me, so I can't check anything right now.
The tuning chips don't work at all. They won't even start the engine.
I'm really at my wit's end.
Translated on 25-09-2026, 14:09.
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Revs High After Warm Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW AAZ: No Acceleration Below 1/3 Throttle Diesel Engine Technology
No new posts TDI Engine: Won't Accept Fuel? Troubleshooting Diesel Engine Technology
No new posts 1,9 TDI 1Z nimmt sporadisch kein Gas an On-Board Diagnostics (OBD)
No new posts Engine Won't Accelerate? Troubleshooting Guide. Diesel Engine Technology
