Fuse keeps blowing? Troubleshooting guide
tdi-seppl
Post29-08-2005, 19:25    Subject: Fuse keeps blowing? Troubleshooting guide Quote
"In my Audi A4 TDI/AFN, the 10A fuse for the interior light and turn signal control for the central locking system keeps blowing repeatedly (after about 1-3 days)."
What could be the reason? Thank you in advance!
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 14-10-2026, 14:47.
Post29-08-2005, 20:28    Subject: Fuse keeps blowing? Troubleshooting guide Quote
Currents greater than 10 Amperes?
SCNR
Have you ever measured with an ammeter in different states?
e.g., interior lights turn on AND the central locking system unlocks AND the hazard lights turn on.
That would be 4 times 21W turn signals, and 20W for the interior lights, which roughly totals 104W.
There are still 16 weeks left for the project.
The 120 watts of the 10A fuse quickly reach its limit.
Is 10A actually the correct size?
Translated on 14-10-2026, 14:49.
tdi-seppl
Post29-08-2005, 21:30    Subject: Fuse keeps blowing? Troubleshooting guide Quote
According to the Audi manual, it is indeed the correct fuse.
ng2000
Post29-08-2005, 21:32    Subject: Fuse keeps blowing? Troubleshooting guide Quote
If your A4 is a bit older, you could compare it to my A6, which doesn't have turn signal control but does have the interior light package, and it's protected by a 15A fuse. A friend who has the same car and retrofitted a wireless central locking system had to increase it to 20A because he had to replace the 15A fuse frequently (probably due to the turn signal control icon_smile.gif.
As I mentioned, I have a 15A fuse installed in my car, but it's an A6 C4.
Martin
Translated on 14-10-2026, 14:50.
tdi-seppl
Post03-09-2005, 16:47    Subject: Fuse keeps blowing? Troubleshooting guide Quote
I've now installed a 15 amp fuse.
But the problem still exists.
I suspect there might be a broken cable near the passenger door.
Translated on 14-10-2026, 14:51.
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuse Keeps Blowing? Get Help Now! On-Board Diagnostics (OBD)
No new posts TDI Repair: Common Issues & Solutions Diesel Engine Technology
No new posts AdBlue error keeps recurring Diesel Engine Technology
No new posts TDI Engine Problems: Emergency Mode Explained On-Board Diagnostics (OBD)
