Passat combination instrument cluster 05.99 to 09.2000 (Solution)
Michael II
Post06-09-2002, 11:01    Subject: Passat combination instrument cluster 05.99 to 09.2000 Quote
VW Passat, models from 05.99 to 09.00.
Sure, I'd be happy to translate the text for you. Please provide the text you would like me to translate.
Code a control unit.
Adjust service interval data.
Reset service interval indicator.
Adjust fuel level indicator.
Adjust power consumption.
Coding the control unit:
Composition.
01 Additional equipment: Brake pad wear indicator.
0 Country variant: Germany.
4 inline-4 cylinder engines.
5. Impulse number.
Table:
XX Code number for optional equipment*
00 No additional features active.
01 Brake pad wear indicator active.
02 Seatbelt warning active.
04 Wash water alarm active.
16. Navigation
If multiple optional features need to be coded, the code numbers for each optional feature must be added together.
X Country code for locale variant.
0 Germany (D)
1 Europe (EU)
2 USA (US)
3 Canada (CDN)
4. United Kingdom (UK)
5 Japan (JP)
6. Saudi Arabia (SA)
7 Australia (AUS)
X: Cylinder count code.
5 5-cylinder engines.
6-cylinder engine.
X Momentum number (K-number)
5 4182
Adjust service interval data:
Channel 43.
Upper limit for the distance traveled before inspection.
Step size: 1000 km.
Channel 44.
Upper limit for the time until the next inspection.
Step length, 1 day.
Channel 45.
Oil quality of the filled engine oil:
Vehicles with fixed maintenance intervals (Part No.: QG0 and Part No.: QG2):
Input value: 00001
Vehicles with gasoline engines and flexible maintenance intervals (PR number: QG1):
Input value: 00002
Vehicles with a 6-cylinder diesel engine and flexible maintenance intervals (part number: QG1):
Input value: 00003
Vehicles with diesel engines and flexible maintenance intervals (PR number: QG1):
Input value: 00004
Channel 40.
Distance traveled since the last inspection.
Step size: 100 km.
Channel 41.
Time elapsed since the last inspection.
Step length, 1 day.
Channel 46.
Total fuel consumption (gasoline engine only).
Step size: 1 liter.
Channel 47.
Exhaust manifold (for diesel engines only).
Step size: 100 km.
Channel 48.
Oil wear (diesel engines only).
Step size: 100 km.
Function: Adaptation.
Channel: 2
Value: 0
Channel: 30.
Range: 120 to 136.
Adjust power consumption display.
It is only possible to adjust the power consumption indicator from 85% to 115%.
The input must be entered in increments of 5%.
Channel: 3
Tschüss
Michael II
Ratings - Passat combination instrument cluster 05.99 to 09.2000
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 2000 instrument cluster malfunctioning Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat combination instrument cluster, year 1998 On-Board Diagnostics (OBD)
No new posts Kombiinstrument Passat Modell 2001 Diesel Engine Technology
No new posts Passat 3B - Issues with Comfort Control Unit / Instrument... On-Board Diagnostics (OBD)
