AGR Valve Mobility: Causes & Solutions
Post15-09-2005, 13:57    Subject: AGR Valve Mobility: Causes & Solutions Quote
Hi.
How does the AGR valve operate in Golf 4 engines?
Does the piston go inside or outside the container?
Going in is simpler; going out would only be achievable with more complex structures in the membrane icon_smile.gif.
Can it be moved manually?
I have a 038 131 501 E here, and I can move the bypass valve, but not the EGR valve.
Translated on 14-10-2026, 0:48.
bafische
Karma: +22 / -0   Thank you, like it!
Post15-09-2005, 14:10    Subject: AGR Valve Mobility: Causes & Solutions Quote
I'm holding the same valve right now. The piston goes inside the canister, and you can't move the EGR valve by hand – it has to seal against over 3 bar of exhaust back pressure.
If you don't need the can for the diverter valve, I can help you find a willing buyer. icon_redface.gif
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 14-10-2026, 0:49.
Post15-09-2005, 14:17    Subject: AGR Valve Mobility: Causes & Solutions Quote
Sorry,
I know you wrecked your car.
But I'm only interested in the storage flap - sorry.
My 1Z is now being taught parking manners icon_smile.gif.
No new posts AGR Valve N18: Replacement & Repair Diesel Engine Technology
No new posts N75 Valve: Function, Problems & Replacement Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Ventil (stillegen???) Diesel Engine Technology
No new posts AGR Valve Calibration: How-To Guide On-Board Diagnostics (OBD)
