I'm new here and need help right away!!!
A3_ASZ_96kW
Post05-02-2007, 13:38    Subject: I'm new here and need help right away!!! Quote
Hello! I've read this forum quite a few times and find it very helpful!
I just tried using the VAG-COM from our workshop to adjust the AGR (Abgasrückführung) settings as described in the technical report.
So, I went into the engine electronics, but I made a small mistake! icon_cry.gif I entered the value 3 during the coding process! Here's the translation:
"Now, under the data, it says:"
01 - Motor electronics.
038906019CK
1.9 R4 EDC 0000 SG 1243
Encoding 3 (This ad is meant to be displayed!!!!)
Company registration number 47791.
Unfortunately, I don't know what I did wrong now!!!???? Is this something serious, or can I continue driving normally?!?!?
I really don't know much about the VAG group at all!
If someone could help me, I would be very, very grateful!
PS: And I still haven't found the measurement block for the EGR! icon_rolleyes.gif
Timo
Post05-02-2007, 13:50    Subject: Subject: I'm new here and need help right away!!! Quote
A3_ASZ_96kW wrote:
I specified the value 3 during the coding process! Here's the translation:
038906019CK
Unfortunately, I don't know what I did wrong now!!!???? Is that something serious, or can I continue driving normally?!?!?
You probably have the engine configured for all-wheel drive, automatic transmission, without ABS, or some other incompatible "settings," depending on which versions your car was offered in. This usually manifests as some strange behavior, error messages, or similar issues.
Damage should not occur, in my opinion. I will try to determine which encoding was active previously and restore it.
The AGR channel is number 3, located under "MWB" and "Adjustments / Adaptation."
A3_ASZ_96kW
Post05-02-2007, 13:57    Subject: I'm new here and need help right away!!! Quote
Thank you for your help!!!
But how do I get rid of the default encoding? Do I need a different ASZ (acceleration sensitivity zone) value there, or are there standard values for this somewhere?
Okay, so it's not giving me any problems when idling or otherwise. Let's see how the week goes!
Timo
Post05-02-2007, 15:10    Subject: I'm new here and need help right away!!! Quote
A3_ASZ_96kW wrote:
But how do I get rid of the standard encoding?!?! Do I need a different ASZ there, or are there standard values for that somewhere?!?
Check out.
http://www.opendiag.org/
(without any guarantee that anything here will fit your car)
A3_ASZ_96kW
Post05-02-2007, 15:16    Subject: I'm new here and need help right away!!! Quote
Okay, I found it and I've already increased the value! So far, it works well icon_biggrin.gif.
While coding, a newly qualified automotive technician helped me, and we have now reset everything to the default settings! icon_cool.gif
Thank you again for the quick help! This forum is really amazing!
Timo
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHF training: Information and details On-Board Diagnostics (OBD)
No new posts Hydros: What happened here? Diesel Engine Technology
No new posts VAG-COM adapter, cable length here Diesel Engine Technology
No new posts Am I in the wrong place? Diesel Engine Technology
