11-10-2005, 9:10 Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE |
Does anyone know if the bearing shells of the idler pulley for the serpentine belt are available separately? I believe they are Teflon bushings that are pressed in.
I mean the folded part with the notch.
http://www.luxus-wg.de/~martin/auto_bilder/Spannrolle/DSC01152.JPG
m; Transparency, Teamwork
Translated on 20-09-2026, 15:01.
Profile PM Garage |
Georg-TDI Guest
11-10-2005, 9:30 Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE |
While I can't give you a direct answer, according to what 'Freundlicher' said, these storage containers should also be available individually.
'In the past, I frequently had issues with the worn-out tensioner in the ribbed belt drive of the alternator. A friendly mechanic offered to replace the belt, pulley, pulley arm, bearing housings, and the tensioner for just under 300 euros. His words were: '...everything needs to be replaced, otherwise you'll be back here in a month because the next part will suffer consequential damage!'
Either it was a typical Volkswagen fairytale, or those bearing shells are actually available individually.
Does the file contain any information about that?
Georg.
Translated on 20-09-2026, 15:04.
Jockel Blaumann
Joined: 03/14/2004 Posts: 249 Karma: +15 / -1 Location: 84478 Waldkraiburg
11-10-2005, 10:35 Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE |
Enjoy your meal!
028 903 312
That could be it.
Hi, Jockel. Passat 35i mit AAZ, CTN Getriebe, LLK - in Rente
"Neu": Bora Variant, ASV
Translated on 20-09-2026, 15:06.
Profile PM Email |
11-10-2005, 21:31 Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE |
028 903 312 is a protective cap for the tensioning roller!
That's something completely different. Transparency, Teamwork
Translated on 20-09-2026, 15:07.
Profile PM Garage |
Jockel Blaumann
12-10-2005, 15:16 Subject: Tensioner Bearing Bowls for 1Z, AHU, AFN, ALE |
dieselmartin wrote: | 028 903 312 is a protective cap on the tensioner roller!
that is something completely different |
Wow!
Okay, I'll search again to see where I got that number from...
Translated on 20-09-2026, 15:08.
Profile PM Email |
