T4 Injectors: Buy Online & Save!
Jürgen
Post21-06-2004, 16:09    Subject: T4 Injectors: Buy Online & Save! Quote
Hello everyone,
Does anyone have any idea where the 216 injectors are used (in T4 engines with 75kW or 111kW)?
'both?). The background is that I have a 75kW T4 model year 2000 sitting there, from...'
I'd like to remove the injectors to test them, possibly in a Passat AFN/automatic.
to test it on my wife. I'd be curious to see how the car performs.
According to VW-Erwin, the opening pressure of the injectors is the same for both power outputs!
Ich habe versucht in den Bosch-Online Ersatzteilkatalog reinzukommen. Previously.
It worked perfectly before, but for some reason, it's not working anymore.
Translated on 28-08-2026, 23:25.
Post21-06-2004, 16:55    Subject: T4 Injectors: Buy Online & Save! Quote
Hi, in my opinion, only in the 111 kW version...
Translated on 28-08-2026, 23:26.
dieselcruiser
Post27-10-2005, 19:16    Subject: T4 Injectors: Buy Online & Save! Quote
Does anyone know what the orifice diameter of the injectors is for the 75kW T4 engine (ACV)?
Translated on 28-08-2026, 23:27.
Rudi
Post27-10-2005, 19:38    Subject: T4 Injectors: Buy Online & Save! Quote
It is in the order of 1Z.
The AFN engine produces a healthy 90 horsepower (although it might produce a bit more soot...).
Rudi
dieselcruiser
Post27-10-2005, 20:27    Subject: T4 Injectors: Buy Online & Save! Quote
And what about the injectors for the 103kW Audi A6 TDI (AEL)?
JanT3TDi
Karma: +2 / -2   Thank you, like it!
Post01-11-2005, 9:16    Subject: T4 Injectors: Buy Online & Save! Quote
I'm not 100% sure, but are these 0.216-inch valves for a 5-cylinder engine?!
T3 Multivan mit 1Z aus '95er Passat + Chip, 3H Getriebe + langer 5ter Gang
Translated on 28-08-2026, 23:28.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts AEL Injectors: Replacement & Performance Parts Diesel Engine Technology
No new posts Fuel Injectors AKN - Buy Now! On-Board Diagnostics (OBD)
No new posts AEY Injectors: High Quality & Performance Diesel Engine Technology
No new posts TDI Injectors: AFN to 1Z Conversion Guide Diesel Engine Technology
