Injector Differences: AHH 90hp vs. AFN 110hp
Mtw13ve
Post20-09-2002, 8:04    Subject: Injector Differences: AHH 90hp vs. AFN 110hp Quote
'Does anyone know if the injectors used in the 90hp Golf engine (AHH or AHU) are compatible with the 110hp AFN engine, and whether they have the same diameter for the injector nozzles? Specifically, is the nozzle size .205?'
Are the AAH and AHU engines the only TDI engines with 90 horsepower?
Please help me, I'm in a hurry...
'Thank you.'
chris
Translated on 01-08-2026, 14:38.
Markus H.
Post22-09-2002, 15:23    Subject: Injector Differences: AHH 90hp vs. AFN 110hp Quote
I can't say for sure about the size of the nozzles, but I believe that the nozzles from the 110 model are not identical to those of the 90 model.
However, I can definitely say that the good old 1Z is still around. It has 90 horsepower.
Translated on 01-08-2026, 14:39.
Thomas
Post22-09-2002, 18:18    Subject: Injector Differences: AHH 90hp vs. AFN 110hp Quote
Hi Chris,
The nozzles are definitely different. The ones from the 81kW machines have larger holes.
I assume you mean ALH and AHU.
Before the AHU, this area was known as 1Z. It was renamed in 1996, but it's essentially the same place.
Greetings,
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 01-08-2026, 14:40.
No new posts 110hp injectors in a 1Z 90hp engine?? Diesel Engine Technology
No new posts AAT vs. AEL: What's the Difference? Diesel Engine Technology
No new posts Seat Ibiza 110PS TDI: Upgrade to G3 Diesel Engine Technology
No new posts AFN Engine: Sudden Power Loss at 120-140 km/h On-Board Diagnostics (OBD)
