Engine Control Units with Aftermarket Support
Post15-09-2005, 10:38    Subject: Engine Control Units with Aftermarket Support Quote
Hi.
In another thread, the topic of "ECU lag" was discussed.
Rudi said he recognized it by the delayed deactivation of the daytime running lights.
My 1Z with 021 AF (MSA12) definitely does not have any after-running; there is no later clicking of the relay 109 that can be heard.
The colleague's ASV (Anti-Slip Valve) is lagging because it clicks later, and the LMM (Linear Motor Module) continues to be energized for a longer period.
Does anyone know when the trailing space was introduced (in the history of development)?
Because it is necessary for the shut-off valve icon_smile.gif.
Translated on 26-07-2026, 4:26.
Rudi
Post15-09-2005, 10:51    Subject: Engine Control Units with Aftermarket Support Quote
Hi Martin,
It likely involved a switch to MSA15.
Rudi
Translated on 26-07-2026, 4:28.
dieseltester
Post29-10-2005, 23:15    Subject: Engine Control Units with Aftermarket Support Quote
The after-run sequence serves to check certain sensors and actuators after the ignition (Kl15) is switched off and the engine has stopped.
No new posts Which batteries still have cell caps? Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI Exhaust Temperature: Max Limit for 1.9L Engine Diesel Engine Technology
No new posts TDI Injectors: Which Models Use the Same? Diesel Engine Technology
No new posts Nachlauf ausserhalb des Toleranzbereiches? Transmission, Chassis, Body & Interior
