Temperature Sensor Replacement
Post01-12-2005, 14:59    Subject: Temperature Sensor Replacement Quote
Yesterday, I replaced my temperature sensor (the dual sensor at the coolant outlet) using a headlamp.
The old one was a 357 919 501 A with a yellow ring, and the new one is a 6U0 919 501 B... (part numbers follow) with a blue ring.
My experiences:
The donor is quite obstructed at the 1Z position!
It's impossible to get it done without getting it wet.
My thumb is thinner than the hole where the sensor goes in.
I currently have about half a liter of cooling water sitting in the garage.
The new sensor shows about 2-3 degrees more under the same driving conditions. But 83 degrees is still too low for me.
Translated on 24-07-2026, 7:33.
Post01-12-2005, 15:13    Subject: Temperature Sensor Replacement: How To & Tips Quote
dieselmartin wrote:
The new sensor shows approximately 2-3 degrees more under the same driving profile.
Is this displayed on the instrument cluster or via MSG and VAGCOM?
Translated on 24-07-2026, 7:35.
Post01-12-2005, 15:50    Subject: Temperature Sensor Replacement Quote
The AI is only showing "Ice Cold - In Between - Roaring Hot".
Of course, using VAGCOM, and for the 1Z model, there's only the MSTG icon_smile.gif.
Post01-12-2005, 16:24    Subject: Temperature Sensor Replacement Quote
dieselmartin wrote:
The AI only shows "Ice Cold - In Between - Roaring Hot".
Well, 3K would probably be about the width of a (thin) pointer.
And if there are a few markings on the scale, I think you should be able to notice such a difference in reaching the operating temperature (without a plateau function), based on my recollection of the G3.
Translated on 24-07-2026, 7:36.
Post01-12-2005, 18:35    Subject: Temperature Sensor Replacement Quote
Is the plateau function disabled when I put the AI into "debug mode," you know, that keyboard shortcut where the fuel gauge fluctuates wildly and the speedometer reading is displayed in clicks?
Translated on 24-07-2026, 7:37.
Post01-12-2005, 18:57    Subject: Temperature Sensor Replacement Quote
dieselmartin wrote:
Does the plateau function turn off when I put the AI into "debug mode," meaning that keyboard shortcut where the fuel gauge fluctuates wildly?
Is the speedometer reading displayed in clicks??
No idea... how does this even work?
Translated on 24-07-2026, 7:38.
Post01-12-2005, 20:10    Subject: Temperature Sensor Replacement Quote
Hello!
Yes, there's a hidden menu in the instrument cluster of a Volkswagen Golf Mk3...
To get there, you need to insert the key into the lock, quickly press and hold the trip reset button. Then turn the ignition on, off, and back on again, release the button, and start the engine...
It doesn't always work, but it can do the trick. You have to quickly turn the ignition on and off...
Once you're in the menu, there are various displays available... I don't know what 1-4 show. 5 is a display test, 6 is an odometer, and 7 is the tachometer... oh yeah, and 8 shows the daily mileage again.
However, I don't know if the tachometer works on Golfs that have clocks instead of actual tachometers.
"displaytest golf" found via Google search.
Translated on 24-07-2026, 7:39.
Mattes AFN
Post02-12-2005, 22:03    Subject: Temperature Sensor Replacement Quote
And with golf carts that have clocks instead of tachometers, you then have a tachometer in the number 7 position.
The tachometers, however, are different. Some of them are accurate to within one revolution per minute. Then there are others with markings at intervals of 20 and 50 revolutions per minute.
Translated on 24-07-2026, 7:41.
Back to top Profile PM Email
No new posts Temperature Sensor Values: How to Read & Use Diesel Engine Technology
No new posts Temperature Sensor G62 Malfunction Diesel Engine Technology
No new posts Temperaturgeber G62 und Geber für Bremsdruck G201 On-Board Diagnostics (OBD)
No new posts Zahnriemen gewechselt... Diesel Engine Technology
