Change Air Filter? [DIY Guide]
Post29-07-2008, 13:41    Subject: Change Air Filter? [DIY Guide] Quote
Hi.
Did I misunderstand something, or was the air filter supposed to be replaced every 30,000 km on older models like the G3 TDI?
I'm surprised that the Passat, which sucks in "a bit" more air thanks to its 2-liter engine and 1.5 bar of boost pressure, needs a new turbocharger at 60,000 miles or even later.
I'm thinking about just giving it to him as a gift.
I also got a new pollen filter for my car's ventilation system; it's supposed to last for 2 years.
Translated on 13-08-2026, 21:07.
Post29-07-2008, 13:59    Subject: Change Air Filter? [DIY Guide] Quote
Okay, so I always change it based on my judgment and only check the indicator later if necessary. If it's already quite full and costs almost nothing, like for a Golf, then you can change it early; it won't hurt. If it still looks good, carefully drain/blow it out and put it back in.
Translated on 13-08-2026, 21:08.
Post29-07-2008, 14:39    Subject: Change Air Filter? [DIY Guide] Quote
Suction and blowing are difficult.
Because, unlike the Golf (3) filter, the outer fins are glued together (as far as I know).
So, you can't really spread it out as much anymore and blow air through it parallel to the folds.
Translated on 13-08-2026, 21:09.
Post29-07-2008, 14:56    Subject: Change Air Filter? [DIY Guide] Quote
Oh, these damn "improvements" that make maintenance more difficult... well, I guess I'll just have to rely on my intuition and experience.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post31-07-2008, 7:49    Subject: Change Air Filter? [DIY Guide] Quote
I don't know what yours looks like, but I've noticed that many newer ones have an additional flow restrictor above the filter that prevents large debris from entering, which might be why the contact time is longer.
"I don't skimp on the IRF either; after all, why should my engine breathe cleaner air than I do?"
Always add activated charcoal!
Are the glued areas due to the water passages at ADAC, so that the filter can withstand it and dry better afterwards? icon_twisted.gif icon_idea.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 13-08-2026, 21:10.
Post31-07-2008, 8:36    Subject: Change Air Filter? [DIY Guide] Quote
I already have a thread about the IRF because, once again, the B version is being offered at a lower price than the original A version.
The adhesive is likely primarily used to dampen resonances and to ensure that the spacing between the lamellae, which is crucial for good airflow, remains consistent.
I'll take a look at the air filter on Saturday... they're probably working on something (like fixing a Multitec issue...).
Translated on 13-08-2026, 21:11.
Post02-08-2008, 18:22    Subject: Change Air Filter? [DIY Guide] Quote
Okay, please provide the text you would like me to translate from German to English. I will only provide the translation.
I finally got rid of that thing (after also being caught in a massive thunderstorm on the highway on Sunday).
Some dust came out, and the lamellae clearly show where they filter and where they are tightly sealed together, because the dirt has caused a break in the seal on one of the lamellae.
I'm going to redo this part.
Translated on 13-08-2026, 21:13.
Post07-08-2008, 19:42    Subject: Change Air Filter? [DIY Guide] Quote
Here's what it looks like after 30,000 km (or miles).
 File size:  182.91 KB
 Viewed:  9936 times
Post08-08-2008, 6:39    Subject: Change Air Filter? [DIY Guide] Quote
Hello Martin,
"I removed the air filter from the bus over the weekend. It has now been used for 22,000 km (which is strange, as it's only 10 months old...). The vanes are not glued. However, there's a kind of diffuser grid underneath the filter, in the dirty airflow. This seems to be working well, because the air filter is evenly soiled. What surprised me was that I apparently sucked in an entire beehive. I found and removed about 30 to 40 of these striped insects from inside the air filter housing. The bus breathes through the vent above the right headlight, so they were flying at exactly that height..."
Translated on 13-08-2026, 21:14.
Post08-08-2008, 8:04    Subject: Change Air Filter? [DIY Guide] Quote
I also have the diffuser grille.
You can even recognize his work by the paper itself, because the louvers of the grid are arranged in different directions.
Regarding your bees, I think it's more likely that they were already present and "settled in" when you parked there. It would be an incredibly unlikely coincidence for them to have been sucked up into the air.
Translated on 13-08-2026, 21:16.
Post08-08-2008, 10:16    Subject: Change Air Filter? [DIY Guide] Quote
Hmm, that could be possible. Was if that was a family car??? Well, the placement of the air intake snorkel would also allow for drawing in ambient air. You can practically put things inside even with the hood closed... It's not like it is in a Volkswagen Golf, for example.
I think the lamella design is good, but the question is whether the even distribution comes at the expense of flow rate. The filter area is the same as that of a Golf, but the surface area is significantly larger, approximately twice as high as that of a Golf.
Translated on 13-08-2026, 21:17.
Post08-08-2008, 10:29    Subject: Change Air Filter? [DIY Guide] Quote
I've also been thinking about throughput.
I have the standard Golf filter insert installed, which has the same surface area as an SDI filter.
Only my turbocharger can achieve up to 1.5 bar of boost pressure (which corresponds to the appropriate intake volume for that pressure), meaning, in the maximum case, it's 2.5 times.
So, either the fuel filter inserts (or 1.9 TDI filters) are being replaced much too early, or mine is being replaced too late.
Translated on 13-08-2026, 21:18.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Air Filter Replacement VW Passat 35i TDI 1Z Diesel Engine Technology
This topic is locked, you cannot edit or reply. K&N Air Filters: Performance & Quality Diesel Engine Technology
No new posts Air Filter LMM Diesel Engine Technology
No new posts A4 B6 2.5 TDI AKE Air Filter Diesel Engine Technology
