Turbocharger rebuilt... Problem!
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Marzocchi
Post28-09-2005, 19:34    Subject: Turbocharger rebuilt... Problem! Quote
Hello everyone.
As announced yesterday, I am replacing the turbo on my Golf IV ALH today. The original turbo was a VNT15 unit. I am installing an ARL Lader GT1749VB. Everything is the same at the charging station, until I need to rotate the housing slightly at the ARL charging station.
Additionally, I have two more issues: The lifters are supported downwards by a bracket attached to the block. To do this, the lifters have a loop that the bracket is attached to. This loop is rotated 90 degrees on the RL lifters. Does anyone know if the bracket is different for the ARL and if I can use that one?
Also, the old air intake hose that goes to the LLK (presumably a turbocharger or intercooler) doesn't fit on the airbox. Has anyone of you got any recommendations for an alternative hose? Pictures are attached. Best regards,
[url]http://.... [Link kaputt][/url]
Golf IV - ALH - Erstzulassung 9/99
Julian
Post28-09-2005, 19:49    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]Die AnhĂ€nge funktionieren fĂŒr Nicht-Mitglieder leider nicht...
Marzocchi
Post28-09-2005, 20:16    Subject: I'm sorry. Quote
Sorry, I forgot. Hier nochmal die Bilder:
 File size:  175.18 KB
 Viewed:  7420 times
Marzocchi
Post28-09-2005, 20:17    Subject: No. 2 Quote
Bitte gib den Text, den du ĂŒbersetzt haben möchtest.
 File size:  188.61 KB
 Viewed:  8814 times
Marzocchi
Post30-09-2005, 7:48    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Schaut seit den Neuerungen denn niemand mehr in dieses Forum ? FĂŒr euch Pros ist es doch kein Problem herauszufinden woher dieser Lader ist:
GT1749VB
GA3 038253016D V013
716213-1s/n D1000111F
oder ?
Viele GrĂŒsse
Post30-09-2005, 10:14    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Marzocchi wrote:
038253016D
Tja, soweit ich weiß hat der ARL Golf einen Lader mit der VAG-Nr. 038253016G
Damit dĂŒrfte Dein Lader aus einem anderen Fahrzeug stammen (frag mich nicht aus welchem, evtl. mit LĂ€ngsmotor?) und deshalb die unpassenden Flansche haben.
Karma: +784 / -0   Thank you, like it!
Post30-09-2005, 10:26    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Ja, ist fĂŒr den ARL.
Die aktuellen 150PS Lader haben einen Clipanschluß auf der Druckseite, passenden Adapter gibt es hier:
http://shop.dieselschrauber.de/product_info.php/cPath/43/
GrĂŒĂŸe, Rainer
oldewurtel
Post03-10-2005, 18:08    Subject: GT1749VB Quote
Hello Marzocci,
Take a look here:
http://www.vwspeed.co.uk/product_info.php?cPath=88_95&products_id=158
There is information stating that the charger with the number 716213-1 (among others) was installed in the golf with 150 hp (MKB?) from the year 2000.
Okay. Oldewurtel
Post05-10-2005, 23:03    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Hierher gehört es und sonst niergens! Musste mal helfen!
Marzocchi Verfasst am: 05-10-2005, 16:24 Titel: Turboladerfrage
Sorry, das ich nochmal damit komme, aber es ist wirklich wichtig. Bind erzeit ziemlich ratlos. Hat irgendjemand von euch schonmal einen Verdichterausgang an einem TDI Turbolader gesehen der Àhnlich aussah wie der eingekreiste auf dem Bild ? Wenn ja, bitte sofort melden. Danke !
wolfi_b
Post06-10-2005, 9:49    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
@Marzocchi:
Wo ist dein Problem? Es wurde doch schon alles gesagt.
038253016D ist vom ARL im Golf IV ( spÀter wurde der 038253016G verbaut.)
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Marzocchi
Post06-10-2005, 10:04    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Problem ist, dass ich jetzt schon verschiedenste SchlÀuche bei VW bestellt habe und keiner auf den Flansch am Verdichterausgang passt.
Normalerweise werden die SchlĂ€uche eingesteckt und mit Klammer gesichert. Diesen Flansch mit den 3 Gewinden hat irgendwie noch niemand gesehen. Hab eschon vermutet, dass jemand da was drangetĂŒdelt hat - aber die Daten des Turboladers stehen ja auf dem VerdichtergehĂ€use kann also auch nicht sein. Sehr dubios !
wolfi_b
Post06-10-2005, 16:23    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Ich denke auch das da jemand was drangebastelt hat. Im AKTE siehts anders aus.
1993 Audi 80 B4 1Z
Hati
Post07-10-2005, 14:30    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]... oder etwas demontiert.
Vielleicht hast du ja mal irgendwie die Möglichkeit, einen originalen ARL zu sichten. Dann wĂŒsstest du genau, wie's original aussieht. Leider sind die nicht so hĂ€ufig anzutreffen... icon_confused.gif
Bei dir in der NĂ€he stehen doch ein paar bei HĂ€ndlern rum. Hinfahren, Probefahrt machen und nachsehen:
Kundenzentrum Walter Schneider KG
Weidenauer Strasse 136
D-57076 Siegen
Autohaus Biederbick GmbH & Co. KG
Almer Feldweg 39
D-59929 Brilon
Menke GmbH
Hauptstrasse 120
D-59939 Olsberg
Autohaus Arens
Warsteiner Strasse 50
D-59872 Meschede
Zak1976
Karma: +0 / -1   Thank you, like it!
Post07-10-2005, 23:39    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Du solltest bei VW nach den Teilen fĂŒr deinen Lader fragen. Es handelt sich um das alte Modell und evtl. hat der einen ander Anschluß. Der Teileservice gibt dir nĂ€mlich meistens nur die Nachfolgetypen wenn sich Teile ersetzt haben und der 038253016D wurde ersetzt obwohl meines Wissens nur Änderungen an der Lagerung vorgenommen wurden (den Nachfolger 038253016G gibt es inzwischen auch in der 5 Revision). MerkwĂŒrdig sieht der bei dir schon aus, ich habe auch den 038253016D aber der sieht anders aus, sicher das es der "D" ist, manchmal sind die Schilder nicht mehr gut lesbar, von der Optik her sieht der mehr aus wie der "F", mach doch mal ein Bild von dem Typenschild
FĂ€hrt mit Golf 3 TDI Umbau (von AFN auf ARL)
Back to top Profile PM Email
Marzocchi
Post08-10-2005, 0:27    Subject: Turbocharger rebuilt... Problem! Translating...
[Translating...]
Hallo danke fĂŒr die Antworten.
@ Hati Probefahrt mit leistungsstarken Modellen bekommt man mit 22 Jahren rel. selten. Klar wenn mans drauf anlegt vielleicht schon, aber nicht mal eben so. Weis auch nicht ob die Modelle zur Probefahrt haben die schon nichtmehr gebaut werden. Und "mal eben so" schaut man sich den Lader ja auch nicht an. Mal abgesehen davon, dass ab 2002 ein anderer Lader mit anderem VerdichtergehÀuse (XX016G) verbaut wurde.
Am Lader hat keiner herumgebastelt - sondern abgebastelt.
Mittlerweile weis ich, das an dem Lader normalerweise so eine Art "SchalldÀmpfer" hÀngt der beim Lader dabei ist und hier fehlt. Einzeln gibt es Ihn nicht. Entweder ich lasse mir jetzt einen Flasch zurecht drehen den ich quasi als Adapter dazwischenklemme oder ich baue mir das VerdichtergehÀuse vom GT1749VB mit der Teilenummer xxx016G dran. Sollte passen und den normalen Anschluss haben.
Habe jemanden gfunden der ein einzelnes GehÀuse hat - ich hoffe es passt.
War mittlerweile unzĂ€lige male bei VW wegend er sache und die haben einfach keinen plan - erschĂŒtternd !
PS: Ist definitiv ein D Typenschild ist noch gut lesbar
Hati
Post08-10-2005, 14:28    Subject: Turbocharger rebuilt... Problem! Translating...
@ Hati
...Weis auch nicht ob die Modelle zur Probefahrt haben die schon nicht mehr gebaut werden.
... es gibt zum GlĂŒck ja noch Gebrauchtwagen...
Die HĂ€ndler, die ich dir aufgelistet hatte, sind grĂ¶ĂŸtenteils in deiner NĂ€he und haben alle jeweils einen IVer Golf mit dem 150PS ARL als Gebrauchtwagen inseriert. Und glaub mir, wenn ein HĂ€ndler einen Gebrauchten verkaufen will, dann muss er auch eine Probefahrt zulassen... icon_lol.gif
Aber du hast ja jetzt eine andere Lösung im Auge.
No new posts Turbolader Instandsetzung 1,9 TDI ASZ Troubleshooting & Guides
No new posts Doku Sharan, PfeifgerÀusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Transporter 7D, MKB ACV, Turbolader-Pfeifen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 2 CLLK umgebaut auf TDI ein paar Bilder Upload
No new posts Problem behoben,neues Problem Diesel Engine Technology
No new posts Turbolader Diesel Engine Technology
No new posts ASV Turbolader Diesel Engine Technology
