Okay, here's the complete log file as saved by VAG-Com:
Unfortunately, the number 19 cannot be encoded as 00006; it always reverts to 00005! Could this be related to the workshop code?
VAG-COM Version: RKS 704.1
Data as of: 20071001.
Monday, May 12, 2008, 9:25:37 PM: 02280
Vehicle type: 3B - VW Passat B5.
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 177,680 km / 110,405 miles
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine. Label file: RKS\059-907-401-AKE.LBL.
Part number: 3B0 907 401 J
Part: 2.5l/4VTEDC G000AG D65
Encoding: 03001
Workshop #: WSC 05311
"One error found:"
01268 - Quantity adjuster (N146)
37-00 - defective.
Readiness: not available.
Address 02: Transmission Label file: RKS\01V-927-156.LBL
Part number: 3B0 927 156 L
Part: AG5 01V 2.5l TDI, Roadworthy Date: 9404.
Encoding: 00000
Workshop #: WSC 44610
No errors found.
Address 03: Brakes/ABS Label file: RKS\8E0-614-111-ASR.LBL
Part number: 8E0 614 111 AH
Part: ABS/ASR 5.3 FRONT D10
Encoding: 00011
Workshop #: WSC 05314
No errors found.
Address 08: Heating/Climate
Label file: RKS\3Bx-907-044.LBL
Part number: 3B1 907 044 D
Component: CLIMATRONIC D2.1
Encoding: 05000
"One error found:"
01206 - Signal for ignition deactivation duration.
35-10 - - - Sporadically
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.LBL
Part number: 6Q0 909 605 B
Part number: 05 AIRBAG VW5 0003
Encoding: 12341
No errors found.
Address 17: Combination Instrument
Label file: RKS\3B0-920-xx2-17.LBL
Part number: 3B0 920 822 A
Component: COMBINATION INSTRUMENT + TRIP COMPUTER, BOO V17.
Encoding: 00165
Workshop #: WSC 00000
Part number: Ident
Part number: VWZ6Z0X1065961
Identification Number: VWZ6Z0X1065961
No errors found.
Address 19: CAN Gateway
Label file: RKS\6N0-909-901.LBL
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Coding: 00005
2 errors found:
01318 - Control unit for fuel injection pump (J399)
49-10 - No communication - Intermittent.
01044 - Control unit incorrectly coded.
35-00 - -
Address 46: Comfort System
Label file: RKS\1J0-959-799.LBL
Part number: 1J0 959 799 AH
Component: 33 Central SG Comfort Unit, part number 0001.
Encoding: 04097
Part number: 1J1959801D
Bauteil: 33 Tõrsteuerger. FS0002F
Part number: 1J1959802E
Bauteil: 33 Tõrsteuerger. BF0002B
Part number: 1J4959811D
Bauteil: 33 Tõrsteuerger. HL0002r
Part number: 1J4959812D
Bauteil: 33 Tõrsteuerger. HR0002H
3 errors found:
00928 - Driver's side central locking control unit (F220)
27-10 - implausible signal - sporadic.
00943 - Driver's side mirror heating (Z4)
35-00 - -
00944 - Passenger side mirror heating (Z5)
35-00 - -
"End"
