Hello, you can create the gear chart yourself; I've done it several times before. The gear ratios and axle ratios were published in the 'Gute Fahrt' magazine test. You just need the rolling circumference of the tires. 195/65/15 tires have a rolling circumference of 1.935 meters, and 205/55/16 tires have a rolling circumference of 1.927 meters. The formula is: nm = v x iges : u x 0.06, or v = nm x u x 0.06 : iges, where nm = engine speed, v = speed, u = rolling circumference of the tires, and iges = gear ratio multiplied by the axle ratio. You put the engine speed on the x-axis and the speed on the y-axis. And now, have fun drawing.
