Is the T4 ACV ESP 074130107N the same as the 074130115B, except for the connector?
Klausen
Post25-11-2005, 12:05    Subject: Is the T4 ACV ESP 074130107N the same as the 074130115B, except for the connector? Quote
I just found this product description on IIIbäääh.
Is the fuel injection pump of your beloved T4 bus broken? And did you buy the wrong one,
IIIbäääh, because of an incorrect or insufficient description? Here is a solution.
"I'm offering an adapter that can be used, for example, to connect a fuel injection pump from a..."
It is possible to install a 2.5L TDI engine from a T4 model year 1996 into a T4 model year 2003.
Since the pumps have the same design but only different connector types,
Is this possible?
The older TDI generation has a 3-pin connector and an 8-pin connector, but only...
7 pins are used, while the newer generation has a 10-pin connector.
Of course, I also offer adapters that work in the opposite direction, meaning you can install a new 10-pin pump in an older TDI engine.
Adapters are also available for AAT and AEL engines from Audi A6 models that have a round connector. Since the pumps from the A6 have the same design, it is possible to install them in a T4 and provide them with power.
The same applies to the new generation of the 2.5L TDI engine, which has the same fuel injection pump as the T4.
Here is a brief excerpt of the MKB models for which this adapter is compatible (or the reverse configuration):
- BBE
- BBE
- ANJ
- ACV
- ON
- AYY
- AJT
- AYC
- APA
- AGX
- AHD
This is not a commercial auction. Therefore, a guarantee is not assumed.
He wants to sell that adapter to someone.
However, the pumps from ACVs manufactured from 1998 onwards are compatible with those from 1996-1997.
I'm new to using "&" and its functions.
And the fact that the pumps from the A6 fit on the T4 is just amazing.
I used to have a 115B (with one connector), but I needed a 107N (with two connectors).
Unfortunately, I haven't tried it to see if it works.
My local Bosch dealer also told me that it doesn't work.
Since everything here is different (i.e., the quantity and the high-pressure component).
Or did he completely lie to me?
But I'm actually thinking more about a complete and utter scam involving an auction house.
Please explain it to me.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New Device, Immediate Issue: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts SDI vs. TDI Injectors: Are They the Same? Diesel Engine Technology
No new posts ECU Same? Check Compatibility Now! On-Board Diagnostics (OBD)
No new posts Water Pump: Should You Replace It Now? Diesel Engine Technology
