Does anyone here know if a flywheel from a PDI engine, for example, with 115 HP or 130 HP, will fit in my car?
Vehicle data:
Passat 3B TDI Variant, manufactured in 1998.
MKB AFN engine with 5-speed manual transmission.
Front-wheel drive.
According to my information, the diameter of PDI products is 240mm, whereas mine is 220mm.
'Will a larger 240mm fan fit on my kW? And is there enough space for the ZMS (presumably referring to a clutch or flywheel) inside the transmission housing?'
'Of course, I can reassemble a ZMS series. However, I would really prefer a stronger one that can handle more torque.'
