AFN control unit
Pred
Post14-11-2004, 3:23    Subject: AFN control unit Quote
Hello everyone.
Can you tell me if all the engine control units (ECUs) for the VW AFN engine are the same?
Okay, for example, Passat and Golf.
Or are they fundamentally different?
Best regards, Olli.
subman82
Post06-12-2005, 15:53    Subject: AFN control unit Quote
I came across this while searching myself.
If anyone is interested, I've done some research on STG (Engine Control Unit) because mine broke. The VW part number is usually 028 906 021, and the index, for example, might be GH, JG, or DF. I was told by VW that these three indices are likely interchangeable, as DF has been replaced by GH and JG. However, if you want to be absolutely sure, you should pay attention to the Bosch number, which should be the same.
My Golf3 AFN TDI used to run with an A4 engine control unit (ECU) and didn't show any errors, and it ran perfectly normally! The coding can be adjusted for all-wheel drive, automatic transmission, or manual transmission, if I remember correctly!
So, it's best to double-check with VW again, using the index, to see if the part is compatible if the number is correct.
Rudi
Post06-12-2005, 16:23    Subject: AFN control unit Quote
Hello Olli,
They are neither fundamentally the same, nor fundamentally different.
Hardware can be the same, but utilized differently by different software.
(For example, the second brake pedal switch sometimes connects to ground, and sometimes to 12V).
Therefore, it is not possible to make a general statement.
Rudi
Post06-12-2005, 16:51    Subject: AFN control unit Quote
At AFN, you can find the 028 and 038 STG models, at least in a very basic form.
Some have a single plug, while others have two.
That's why they can't all be the same.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts Control Unit: What it is & How it Works Diesel Engine Technology
No new posts GRA for AGR Valve Control Unit On-Board Diagnostics (OBD)
