How to code US-style features in a Golf V?
apacherider
Post05-12-2005, 10:36    Subject: How to code US-style features in a Golf V? Quote
Hi there!
Is it possible to program the turn signals on a Volkswagen Golf V so that the brake light blinks instead of the normal turn signal (US style)? The front lights are already working (the turn signals light up with the parking lights at 30% brightness).
" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema fßr andere Leser nutzlos!
Bitte nutze 'Attachment hinzufĂźgen' bzw. das Upload Forum hier.
/my.php?image=pict01763xa5rp.jpg" target="_blank" class="postlink" rel="nofollow">[img][/img]
Best regards, Conny.
http://img203.
/img203/2593/pict01763xa5rp.th.jpg{MARKER}{MARKER}
VW Golf V Trendline 1,9/90PS
Wer nie etwas versucht, dem erscheint alles unmĂśglich !!!
Ross-Tech-Support
Post05-12-2005, 11:16    Subject: G5 turn signal... Quote
Have you tried this yet?
Select STG 09 (Onboard network).
STG Lange Encoding -> Function 07
Byte 15 - Replace left/right rear light function with left/right rear turn signal function.
(Resolution: 1% / Standard: 0%)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock/code GRA Golf VII On-Board Diagnostics (OBD)
No new posts Golf 6: RCD510 Coding Guide & Instructions Transmission, Chassis, Body & Interior
No new posts Golf VI: CAYC Engine Coding (or Not) On-Board Diagnostics (OBD)
No new posts AI coding?! On-Board Diagnostics (OBD)
