VEHICLE IMMOBILIZER ACTIVE!!! POLO 6N
lkt
Post08-12-2005, 12:01    Subject: VEHICLE IMMOBILIZER ACTIVE!!! POLO 6N Quote
Okay, I have a Polo from 1994 with a Generation 1 VAG-COM interface. I'm getting sporadic "Engine control unit locked" errors on both the 510 and 504 interfaces, and even using a spare key doesn't help. The engine starts but immediately shuts off. The WFS system isn't reporting any specific error codes.
It was definitely treated somewhere...
Geradeaus kann jeder schnell fahren...
Translated on 12-07-2026, 5:40.
Back to top Profile PM Email
Post08-12-2005, 12:32    Subject: VEHICLE IMMOBILIZER ACTIVE!!! POLO 6N Quote
Go to the VW dealership, take 14 euros with you (cash). Buy a new ignition coil (it's the thing near the ignition switch), install it, and that should fix it.
Sometimes, a quick tap from underneath the ignition switch can also help temporarily.
Translated on 12-07-2026, 5:41.
lkt
Post08-12-2005, 12:46    Subject: reading coil Quote
I tried a different reading coil from another Polo, but that wasn't the problem.
VAG-COM also recognizes the key. If, by chance, neither key works...
"But the battery was dead. Maybe the control unit needs to be reprogrammed for WFS?"
Translated on 12-07-2026, 5:42.
Ross-Tech-Support
Post08-12-2005, 15:05    Subject: VEHICLE IMMOBILIZER ACTIVE!!! POLO 6N Quote
Lesespule tauschen ist immer so die Standardantwort die man bekommt, zahlt ja am Ende auch der Kunde die Teile, wen interessierts also... icon_confused.gif
First, check the sensor data groups to see if they indicate a communication error related to the reading coil. If so, clean the contacts on both the control unit and the reading coil. I consider it unlikely that both keys are defective.
Da du keine konkreten Fehlercodes gepostet hast ist es schwierig zu sagen wo genau der Fehler liegt, pauschal ließen sich aber vermuten, das im WFS-Steuergerät gar kein Fehler gespeichert ist, sondern ausschließlich im Motorsteuergerät... sollte dem so sein würde ich mir mal die Stromversorgung der Steuergeräte anschauen. icon_cool.gif
P.S.: No, after a power supply failure, the WFS does not need to be re-calibrated, but as mentioned before, check the power supply (fuses/relays)... icon_wink.gif
Translated on 12-07-2026, 5:43.
No new posts SDI Polo: Specs, Price, and Review Diesel Engine Technology
No new posts POLO 9N Servopumpe On-Board Diagnostics (OBD)
No new posts VW Polo 6R: MFA Instrument & VAG-COM Diagnostics On-Board Diagnostics (OBD)
No new posts VW POLO 9N Timing Belt Replacement BBY Gasoline Engine Technology
