A4 8E2/8E5 - Possible various error memory messages (Solution)
vagtuning
Post25-12-2005, 0:25    Subject: A4 8E2/8E5 - Possible various error memory messages Quote
Error:
Vehicle is jerking, has no power, limp mode, no acceleration.
Also häufige Fehler 00777 - Gas pedal position sensor - implausible signal
Cause:
Damaged/broken lid of the E-box in the front left water tank.
This allows water to enter and potentially come into contact with some terminals.
Test:
Remove wiper arm brackets, remove windshield cowl.
Remove the E-Box, making sure ALL screws are securely tightened.
If the lid is open, check the surrounding seal for dents and ensure it is not sticking.
Inspect for damage, such as warping, cracks, and breaks.
Remedy:
Replace the lid AND screws, clean contacts if necessary, and replace them.
Ratings - A4 8E2/8E5 - Possible various error memory messages
Average rating: 4.00 - worst rating: 4 - best rating: 4 - number of ratings: 1 - View ratings
No new posts Camshaft Bolt Service: PD Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation of driving behavior deficiencies, various v... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB & MSG Error Codes: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Search logs with MWB 8+10, various MKBs. On-Board Diagnostics (OBD)
No new posts EGR Valve for 2.0L TDI Engines Diesel Engine Technology
No new posts Passat: Engine Stalling, Relay Problems - Fix! Diesel Engine Technology
No new posts Galaxy in Emergency Mode: Error Codes & Fixes On-Board Diagnostics (OBD)
