div. Golf 1J TDI and Gasoline, gradual loss of power (Solution)
Post17-12-2005, 15:33    Subject: div. Golf 1J TDI and Gasoline, gradual loss of power Quote
Problem:
Gradual performance loss/Maximum speed (Vmax) is no longer achieved.
Cause:
Clogged filter in the air intake. In some cases, vehicles were equipped with air intakes intended for Nordic countries, but these were not designed for those specific countries.
Solution:
Inspect the air intake before the air filter by removing the air filter housing and intake. If this air intake has a bypass valve and a screen, then the screen should be removed from the air intake. Afterwards, the intake can be reinstalled.
Ratings - div. Golf 1J TDI and Gasoline, gradual loss of power
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V 1.4 Gasoline GRA retrofit failed Electrical Systems, Vehicle Electronics, Multimedia
No new posts Coolant Leak Diagnosis: Early Signs & Solutions Diesel Engine Technology
No new posts Slow coolant leak, Passat, engine code CAYC / year 2014 Diesel Engine Technology
No new posts Gasoline in TDI Diesel Engine Technology
