No oil temperature reading in VAG-COM - faulty G8 sensor?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Fab
Post31-12-2005, 17:04    Subject: No oil temperature reading in VAG-COM - faulty G8 sensor? Quote
"The oil temperature reading remains at 0.0% even after a long drive. Is the sensor defective? But wouldn't it then display an error? Is the G8 sensor located on the oil filter housing on the 9N AXR engine, or is it the 'Li' sensor located on the engine block?" Anyway, I couldn't find any loose cables or anything like that...
In the background, you can see the label file with the relevant line: 007,2 ... Is there possibly a programming error?
[img][/img]http://img408.
/img408/3601/oel5mf.jpg{MARKER}
9N AXR
Ross-Tech-Support
Post31-12-2005, 17:36    Subject: No oil temperature reading in VAG-COM - faulty G8 sensor? Quote
Well, if you simply take a label file and rename it, it can easily happen that the values don't match up. That's why it's also said that label files, which are actually intended to work with redirects, SHOULD NOT be renamed in order to maintain compatibility with older VAG-COM versions...
"Perhaps the following is more appropriate in your case:"
007,2,Status,Fuel Cooling,Target Value (OFF): 0 %
Target Value (ON): 100 %
P.S.: Perhaps it would be helpful to contact the author directly next time; they might know more, or perhaps they already have a more recent version ready.
Fab
Post02-01-2006, 0:28    Subject: No oil temperature reading in VAG-COM - faulty G8 sensor? Quote
A forum member from the Saarland gave me a tip on where to find Labe files for my vehicle's registration number and engine code. Since I didn't have a second one to compare it to, I assumed it was correct. At least, my vehicle's information, including the engine code and kW rating, is listed in the header of the Labe file.
Thank you!
P.S.: Perhaps it would be helpful to contact the author directly next time; they might know more, or may have had a more up-to-date version ready for some time.
I read the "Forum Rules and Common Mistakes" -> Unfortunately, he's not responding... I still had a few questions.
9N AXR
Ross-Tech-Support
Post02-01-2006, 1:59    Subject: No oil temperature reading in VAG-COM - faulty G8 sensor? Quote
Fab wrote:
-> He unfortunately doesn't respond... I still had a few questions.
Hmm... mysterious... answering what question? Sure, here's the translation:
"Email?"
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Kühlwassertemp-Anzeige defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 111kW AHY, auxiliary heater defective Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Keine Leistung mehr - Turbo defekt? Diesel Engine Technology
No new posts Keine Leistung unter 2400 Umdrehungen! VTG defekt? Diesel Engine Technology
No new posts Keine MWB? On-Board Diagnostics (OBD)
No new posts 776 No communication Diesel Engine Technology
