Master Cylinder for Mark20-ABS: Which Fit?
Henrik
Post18-01-2006, 11:50    Subject: Master Cylinder for Mark20-ABS: Which Fit? Quote
Hello!
I installed G60 brakes on the front and rear, and originally, the vehicle came equipped with the Mark20 ABS system and a 22.2mm master cylinder.
I now want to install a larger one; there are still (very rare) models of the Golf 3 with a 23.8mm size.
So, I either need to get one myself, or could I also use one from a Golf 4?
They also have the Mark20, but usually the Mark20i (with EDS).
The question is whether the master cylinder from a G4 or S2, or something similar, will fit. Or, at the very least, whether the brake booster assembly (including the master cylinder) will fit (because those from the Golf 3 and similar models are more commonly found).
Thank you very much!
Translated on 11-10-2026, 19:28.
No new posts Gearbox DHF, Long 5th Gear: Compatible Ratios? Diesel Engine Technology
No new posts MJ 01er Leon: Mark20 or Mark60? Transmission, Chassis, Body & Interior
No new posts Master cylinder balance port blocked Transmission, Chassis, Body & Interior
No new posts Brake Pedal Stuck? Check Master Cylinder Now! Transmission, Chassis, Body & Interior
