Glow plug light illuminates intermittently with engine running
Roadrunner505
Karma: +7 / -6   Thank you, like it!
Post19-12-2005, 15:20    Subject: Glow plug light illuminates intermittently with engine running Quote
My car battery was dead again just now. I accidentally short-circuited the car with a different battery, and then I drove it into the driveway to charge it.
I noticed that the preheating light would occasionally come on. Sometimes 10 seconds, sometimes 3...
It probably doesn't have anything to do with the dead battery - the engine was running, after all...
I've found some threads on the topic of "glow plug light is on" - but in those cases, the engine wouldn't start... in my case, everything else seems "normal."
Translated on 07-07-2026, 2:01.
Post19-12-2005, 17:21    Subject: Re: Glow plug light intermittently illuminates with engine running Quote
Roadrunner505 wrote:
I noticed that the preheating light sometimes came on.
Sometimes for 10 seconds, sometimes for 3...Did it stay on constantly? Then it's probably a glitch in the AI or some kind of wiring issue -> get the circuit diagram and start troubleshooting.
If it's blinking -> read the error memory.
Translated on 07-07-2026, 2:02.
Roadrunner505
Post19-12-2005, 19:03    Subject: Glow plug light illuminates intermittently with engine running Quote
No, it really shone brightly. It could really be any bridge - even in the dark, you can see that the lamp is glowing very faintly... damn.
Translated on 07-07-2026, 2:03.
hb2000
Post06-01-2006, 21:35    Subject: Glow plug light illuminates intermittently with engine running Quote
Perhaps you've had a small water leak in your car icon_wink.gif.
and now, the copper worm is spreading due to the high humidity icon_wink.gif.
Okay, seriously now - The indicator light for the rear fog lights occasionally illuminates in my Passat's instrument cluster.
Specifically, whenever I notice moisture in the adapter at the AHK socket, I apply contact cleaner, and then it works fine again.
Translated on 07-07-2026, 2:04.
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI: Glow Plug Light On, Engine Won't Start On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Glow plug light flashing, DPF and engine check lights on! Diesel Engine Technology
No new posts N75 Valve Test: How to Check While Running On-Board Diagnostics (OBD)
No new posts Polo 9N3: Oil pressure light flickers intermittently Diesel Engine Technology
