pschaefer Blaumann
27-01-2006, 21:05 Subject: ECU Remapping: Unlock EDC15 Potential |
...but how?
Stupid question: Can I safely remove the EDC15 unit? And will I be able to reseal it afterwards? The four screws are obvious, but the housing is probably glued on.
Please provide a brief guide...
Thank you & Best regards.
Peter.
Translated on 25-07-2026, 5:56.
Rudi Guest
27-01-2006, 21:33 Subject: ECU Remapping: Unlock EDC15 Potential |
Remove the screws and then apply gentle force.
Rudi
pschaefer Blaumann
27-01-2006, 21:56 Subject: ECU Remapping: Unlock EDC15 Potential |
Quote: | | Remove the screws and then apply gentle force. |
Thank you! The adhesive could actually be removed quite gently after I had warmed it up a bit with the hairdryer... (ugh, you can really see what kind of fibers this sealant pulls).
Okay, it's not unlocked yet, unfortunately, and hasn't been chip-tuned, so it's not unlocked  ... The software version is still the same as mine, even though it says 12.05.03 on it  . Anyway, I'll bother the dealer about the PIN tomorrow, and then we'll see what happens...
Translated on 25-07-2026, 5:57.
Troubleshooter Guest
28-01-2006, 9:13 Subject: ECU Remapping: Unlock EDC15 Potential |
Okay, it's not unlocked yet, unfortunately, and hasn't been chip-tuned, so it's not unlocked  . The software version is still the same as mine, even though it says 12.05.03 on it  . Anyway, tomorrow I'll bother the dealer about the PIN, and then we'll see what happens...
What do you want to use the base for?
The device works perfectly via OBD, or the 400 series chip can be soldered very quickly anyway  .
Best regards.
Matthias.
Translated on 25-07-2026, 5:59.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
28-01-2006, 11:10 Subject: ECU Remapping: Unlock EDC15 Potential |
...and with a little bad luck, there might not be enough space for the locking mechanism of the base  .
Translated on 25-07-2026, 6:00.
Profile PM WWW Garage |
pschaefer Blaumann
28-01-2006, 18:17 Subject: ECU Remapping: Unlock EDC15 Potential |
Quote: | | Why would you need to socket it? This thing can be easily connected via OBD, or the 400 chip is soldered very quickly anyway. |
Well, I only have VAG-COM, and I was thinking more of a regular programmer. And if something goes wrong, it's better to just solder once – the socket itself, you know  .
Quote: | | ...and with a bit of bad luck, there might not be enough space for the base to lock properly. |
I was actually thinking of a standard PSOP44 package... But that won't be vibration-resistant or suitable for automotive applications, will it?
Translated on 25-07-2026, 6:01.
28-01-2006, 20:38 Subject: ECU Remapping: Unlock EDC15 Potential |
I was actually thinking more about a standard PSOP44... But that won't be vibration-proof or suitable for automotive applications, will it?
As Paul Panzer would say:
Absolutely!
It's quite possible that after driving over a wave at a slightly higher speed, your vehicle might come to a stop.
What else would I be interested in knowing?
Do you have a soldering iron, lighter, and the appropriate file?
Because if not, then see.
/viewtopic.php?t=11503&highlight=
What happens if someone solders something onto your ECU?
Best regards.
Matthias.
Translated on 25-07-2026, 6:03.
pschaefer Blaumann
28-01-2006, 21:22 Subject: ECU Remapping: Unlock EDC15 Potential |
Quote: | | Do you have a programmer, soldering iron, and a suitable file?? |
"I have a soldering iron and SMD rework tools available, but I'm still missing the right file."
For background information, please see here:
/viewtopic.php?t=11404
I'm mainly interested in the more recent data (a small test to see if it makes a difference with the automatic transmission). That's why I got this MSG from eBay, and it seems to be working: the engine starts but then shuts off again. This is because: it hasn't been programmed yet, and the seller didn't want to give me the PIN today  . Well. I'll try somewhere else.
Another reason for the STG was that I had been considering sending it to Rainer. However, since I need my Golf every day, this hasn't been possible so far – but a "second MSG" is quite practical in that regard  .
Translated on 25-07-2026, 6:05.
