Golf 3 Glow Plug Problem (1Z Engine)
müllo
Post15-01-2006, 17:13    Subject: Golf 3 Glow Plug Problem (1Z Engine) Quote
'I've been experiencing starting problems with my 1Z lately, and I suspect it's a glow plug issue. Whenever the temperatures drop below -5°C at night, the car is very difficult to start in the morning, sometimes requiring 3-4 attempts. The crankshaft issue has already been resolved.'
'When I turn the ignition key in the morning at the temperatures mentioned above, the glow plug indicator light only comes on briefly (less than 1 second). However, a relay in the engine compartment engages and then disengages after about 5...10 seconds, without the glow plug light illuminating. (My assumption is that this is the relay for the glow plugs located under the fuse strip in the engine compartment.) I have already checked the following things, but I cannot draw the correct conclusions from the results.'
(1) 50A circuit breaker on the circuit breaker panel checked and okay.
(2) Checked the wiring harness in the engine compartment; it's okay.
(3) Coolant sensor disconnected and ignition on.
-> As described above, the relay engages and remains engaged for a relatively long duration (15...20 seconds) before disengaging. However, the light bulb still doesn't stay on continuously; instead, it turns on briefly (t << 1 second) after being activated and then immediately turns off.
(4) Relay 109 engaged, bulb continuously lit.
Can relay 109 cause a fault in the heating system? Does anyone have any suggestions?
Thomas.
Translated on 12-09-2026, 22:40.
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASZ engine in Golf 2 Diesel Engine Technology
No new posts Golf TDI 4: Buying Guide & Engine Info Diesel Engine Technology
No new posts Which engine in the VW Golf IV!? Diesel Engine Technology
No new posts AGR Golf 5 105PS: Engine Management System Diesel Engine Technology
