Defective 1Z Flex Pipe: Who is Liable?
Go to page: 1, 2, 3  Next
Post06-02-2005, 10:12    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
HI,
ich hab lange genug gezoegert, bis ich am 9.4.2003 mein Flexrohr (und dadurch bedingt auch den Kat hab neu machen lassen) - in ner org. VW workshop.
"Now, for the past few days, I've been experiencing a new (but familiar) humming sound at approximately 1050 and 2100 RPM (indicating standing waves, of course)."
Yesterday, on a private stage, I could hear (as I did before) a wonderful noise that disappeared when I lifted the exhaust system. Directly touching the flexible pipe made the noise disappear as well. A former VW employee confirmed my suspicion that the flexible pipe "is worn out."
Do I have a 24-month warranty on the material?
"How can I best get this approved by VW? Theoretically, they could say, "No, no, that drone noise doesn't come from the flex pipe, it's... something else entirely."
Soon, I'll be ready to get rid of the pipes and the AC unit and install the AHU (Air Handling Unit) instead. icon_evil.gif
PS: Of course, the pipe still looks nice on the outside icon_evil.gif.
Translated on 08-09-2026, 9:45.
Roadagain
Post06-02-2005, 10:39    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
Is that a rumbling sound, like the exhaust is loose and hitting something?
Prioritize during the tour?
We had the same problem with our A4... New brackets for the exhaust helped fix it... They probably just wear out over time.
Greetings.
Translated on 08-09-2026, 9:47.
Polo2004
Post06-02-2005, 11:10    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
Okay, so if the flexible pipe is defective and you have the invoice, there usually aren't any problems with the warranty. So, go to Audi & VW and have them replace it.
Best regards, Christian.
Translated on 08-09-2026, 9:48.
Post06-02-2005, 11:20    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
No, the erasers can't be it, because they are relatively new. I looked at them very carefully again yesterday.
Furthermore, the new/familiar noise suddenly appeared, perfectly coinciding with what would happen if a flexible pipe had suddenly burst.
Ja, ich hab die org. Invoice pending.
Am I covered by a 2-year warranty/guarantee/product liability for parts on my vaping device?
Or does it not matter to VW when the part fails (5 minutes after installation or 22 months later)?
Translated on 08-09-2026, 9:49.
JRoth
Post06-02-2005, 14:01    Subject: Flex Pipe Failure: Common Issue After 2 Years? Quote
Hi Dieselmartin!
I had the exact same problem with the flexible pipe. It took me quite a while back then to figure out that the vibration noises at idle were coming from the defective flexible pipe.
came. I bought the flexible pipe separately at the time and welded it in. It took some work, but it was much more cost-effective.
Well, after 2 years, it suddenly started making that clacking noise again.
I believe that the "AHU" modification, specifically the addition of the two rubber supports in the area of the trouser leg, is truly necessary if you want to achieve lasting peace and quiet, literally.
I know: That probably doesn't help you much...
But: Misery loves company...
JRoth
Passat Variant 35i 1Z 05/02 - 01/05
Ford Galaxy AFN 01/05 -07/06
Ford Galaxy 08/06 - 08/09
Translated on 08-09-2026, 9:50.
Polo2004
Post06-02-2005, 18:36    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
You have a 24-month warranty on this part. Whether it breaks 5 minutes after installation or a day before the warranty expires, it is covered by the warranty and will be replaced free of charge.
'In the past (about a year ago), it was even the case that if you bought, for example, a head gasket, installed it yourself, and after about 5,000 km it started leaking again, VW & Audi would even replace it for free. I mean, you could take your car to the workshop, and they would repair it for free. Now it's different. Now, if you install it yourself, you get nothing, maybe just the part itself if you're lucky.'
I also think it's right to some extent, because if someone tinkers with something who has no idea what they're doing, and installs the cylinder head incorrectly, what can VW be responsible for? Now they've finally realized it, and they're no longer paying anything for repairs done by customers themselves.
Translated on 08-09-2026, 9:53.
kapernaum
Post06-02-2005, 22:57    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
Hello Martin,
Here's a summary regarding the warranty:
http://www.verbraucher-urteile.de/kauf/faqkaufcontent.html
Translated on 08-09-2026, 9:54.
Post07-02-2005, 14:17    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
Another question regarding the overall problem:
In 2003, I had an inspection done to ensure that the 12-month warranty on the used car remained valid.
Since then, I haven't needed to have the car inspected, because I can already refill the windshield washer fluid myself icon_twisted.gif.
The inspection with flexible pipe replacement was carried out on April 9, 2003, at approximately 136,000 kilometers.
Now, the date is February 7, 2005, and the mileage is 184,000 km.
Can they refuse to cover the costs for the repair, simply because I didn't have the car inspected at a Volkswagen service center? Even though the inspection has nothing to do with the pipe and the defect that occurred a few days ago?
m
Translated on 08-09-2026, 9:55.
Post07-02-2005, 14:30    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
@ kapernaum
In the article you linked, it repeatedly mentions that the defect must have existed "at the time of delivery."
That's exactly what's NOT the case for me.
My flexible pipe lasted for 22 months, then it started to make a gurgling noise, just like the old one that I had removed in 2003 because of that same noise.
Do I now have any legal right to expect that the product (Flexrohr) will maintain its desired quality (i.e., not make a whistling noise) for 24 months?
Translated on 08-09-2026, 9:57.
Marcus_Nbg.
Post07-02-2005, 15:53    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
Hello Dieselmartin,
First, it's important to determine whether you have a warranty or if only the 2-year legal guarantee for parts and labor applies. This is usually indicated on the invoice.
In the case of a warranty claim, VW is responsible. However, in the case of a guarantee, you are. In the latter case, you have to prove that the defect existed since the beginning of the guarantee period, meaning that the part was faulty from the start.
It's best to visit the workshop (before the 2-year warranty expires!) and hear their opinion on the problem and what solution they propose.
Marcus.
Translated on 08-09-2026, 9:58.
Polo2004
Post07-02-2005, 16:29    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
If an official invoice for the part and its installation is available, and the entire thing breaks down within the warranty period, regardless of whether the inspection was performed or not, it will be replaced at no charge icon_eek.gif.
Translated on 08-09-2026, 9:59.
Post07-02-2005, 16:41    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
I still don't quite understand if there aren't too many terms and deadlines being confused here.
If Marcus is 100% correct, then the flexible pipe could break after 5 minutes, because it was installed flawlessly and handed over to me in perfect condition - something that VW, or whoever, can prove.
Then every single part of the car would be "less secure" than the IT stuff from MediaMarkt?!?!?
Because I'll get a new one, even if it "explodes" in my living room first!
Unless we define a defect as "the pipe doesn't last even 24 months" - but I only know that NOW!
I will definitely go to Volkswagen tomorrow and I will have all the necessary documents with me.
I bet they'll just say, "It's not broken, a drone always makes that noise."
Then I guess I'll have to drive around again and ask other unsuspecting workshops if they believe me that it's broken...
Translated on 08-09-2026, 10:01.
Marcus_Nbg.
Post07-02-2005, 16:56    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
@Dieselmartin
Of course, the part can break within 5 minutes, but then VW has to prove that it was okay when it was installed. If it breaks down after more than 6 months, you have to prove it, which you probably won't be able to do! => 'Warranty' is limited to 2 years!
'If you have an explicit warranty, VW must replace the part if it breaks within the warranty period, because a so-called durability guarantee is provided. 'Warranty' may be limited to one year, but 'guarantee' always applies in addition.'
Translated on 08-09-2026, 10:03.
Post07-02-2005, 18:06    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
haha!
Now things are getting interesting.
0800-VOLKSWAGEN says:
24-month WARRANTY on original parts - but not on wear and tear items.
And now I remember that, with VW, the exhaust system that wears out probably starts from the turbocharger onwards.
That means the flexible pipe and the catalytic converter would be considered wear-and-tear parts, which is completely unacceptable to me as a customer, given the prices of these components.
But tomorrow I will have more information to share.
Translated on 08-09-2026, 10:04.
Post07-02-2005, 18:12    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
AAAAAAAAHHHHHHHHHHHHHH
The Flexrohr promotion in 2003 would have been even 100 euros cheaper if it included AHU parts!
SHIT
AHU: Flexible duct with cat. 511, bracket 11.
1Z: Flexible pipe 254, adapter 8, category 354, screw 3.
m
Translated on 08-09-2026, 10:05.
Post07-02-2005, 18:37    Subject: Defective 1Z Flex Pipe: Who is Liable? Quote
.... However, since January 1, 2003, VW no longer offers a guarantee, but only a warranty, and that is a huge difference! In this case, Martin unfortunately has to prove that the damage existed from the beginning (except within the first 6 months). If the dealer (and only to the dealer can a warranty claim be made) doesn't want any trouble, he will be accommodating and handle the matter under the warranty.
By the way, almost all German car manufacturers do not offer a warranty, but only the legally required guarantee (with the exception of OPEL!).
Translated on 08-09-2026, 10:07.
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Defective ASZ Battery After 13 Months? Diesel Engine Technology
No new posts Passat, manufactured 11/97 (4 wheel alignments in 12 mont... Transmission, Chassis, Body & Interior
No new posts Flexible pipe broken again! Should all engine mounts be r... Transmission, Chassis, Body & Interior
No new posts Timing belt condition after 80,000 km + 30 months, how is... Diesel Engine Technology
