AGR Fault: Audi 8P BKD Engine Problems?
vagtuning
Post13-02-2007, 19:49    Subject: AGR Fault: Audi 8P BKD Engine Problems? Quote
Can someone with expertise confirm this for me?
Here is a log:
/download.php?id=1892
It seems like the EGR valve is stuck in a slightly open position on that box.
I find the discrepancy between the planned and actual results quite significant!
Or is that normal for these boxes? I absolutely can't imagine it being so.
The A4 models equipped with the BLB engine do not exhibit these extreme variations.
It's an 8P model with a 2.0 TDI engine (BKD), without a DPF (Diesel Particulate Filter).
It would be helpful. The vehicle is sluggish in the upper RPM range and occasionally starts very poorly.
Translated on 23-08-2026, 19:17.
Malte1408
Post13-02-2007, 22:57    Subject: AGR Fault: Audi 8P BKD Engine Problems? Quote
You probably mean the high airflow at full load? The setpoint is well regulated under partial load.
A friend's car with a similar engine also has an extremely high air intake at full load, but it doesn't have any issues or complaints.
/download.php?id=1899
If the air mass were that high because exhaust gases are being recirculated back into the intake through the EGR system, then it would likely cause a significant amount of soot buildup.
Translated on 23-08-2026, 19:19.
vagtuning
Post13-02-2007, 23:04    Subject: AGR Fault: Audi 8P BKD Engine Problems? Quote
I can't open either of the files, but if others are having the same problem, I've also found some similar examples, as well as others that aren't nearly as extreme.
Yes, of course, you're right. That's what I meant.
Translated on 23-08-2026, 19:20.
Malte1408
Post13-02-2007, 23:09    Subject: AGR Fault: Audi 8P BKD Engine Problems? Quote
vagtuning wrote:
I can't open either of the files.
icon_eek.gif I was probably editing something at the time and had forgotten to use the upload area.
haithamina
Post14-02-2007, 9:46    Subject: AGR Fault: Audi 8P BKD Engine Problems? Quote
Okay, I definitely don't see any signs of an open EGR valve sticking. The mass airflow value is always high, or as Malte mentioned, it's well regulated at partial load. Those very high values at full load are probably more likely due to the cold season, I think. The sluggishness or poor starting from the top end probably has other causes than the EGR rate or the mass airflow sensor readings.
haithamina
Translated on 23-08-2026, 19:21.
No new posts Error light, indication of defective lamps General Tips
No new posts Different log BKD to 8P BKD, possibly with faulty AGR val... Upload
No new posts What probably broke? Diesel Engine Technology
No new posts PD Tuning: Cheap Options & How They Work Diesel Engine Technology
No new posts 01268 Quantity setting (upper limit) error, likely found On-Board Diagnostics (OBD)
