Alternator Alternatives: 028903026G Replacement
reuselkopp
Post30-01-2006, 21:43    Subject: Alternator Alternatives: 028903026G Replacement Quote
Can any other 120A alternator be used, or is it necessary to buy the exact same alternator that was originally installed?
Greetings.
Reuselkopp.
Translated on 11-09-2026, 12:09.
mullemaus
Post30-01-2006, 23:10    Subject: Alternator Alternatives: 028903026G Replacement Quote
You can reach us at 028 903 026, or the 97VW 10300 EA from Ford also fits, or is of the same design. icon_wink.gif
Translated on 11-09-2026, 12:10.
reuselkopp
Post31-01-2006, 8:06    Subject: Alternator Alternatives: 028903026G Replacement Quote
"Isn't it true that the alternator must match the engine code? I have an AFN engine, which was also used in many other models. Different alternators were installed in those models. Actually, only the freewheel mechanism in my alternator is defective, and before I spend 90€ on a new one, I could buy a used one from E***. Or is the freewheel mechanism available somewhere cheaper?"
Greetings.
dieter
Karma: +13 / -0   Thank you, like it!
Post31-01-2006, 8:31    Subject: Alternator Alternatives: 028903026G Replacement Quote
"Being stingy is awesome, or what?"
Before I would buy a cheap, unreliable clutch from 321, I would rather buy a new clutch pack, but everyone is free to do as they please.
By the way, you can find cheaper options for the "free-roaming" feature; just use the search function, and you'll find plenty of information.
Greetings,
dieter
T3 syncro 16 AFN
Translated on 11-09-2026, 12:11.
Post31-01-2006, 8:45    Subject: Alternator Alternatives: 028903026G Replacement Quote
... or I can give you my "non-free-spool" reel, because I specifically upgraded it with a free-spool function and now I have the fixed-spool reel left over.
Translated on 11-09-2026, 12:12.
No new posts AFN Engine Control Unit: Compatible Alternatives On-Board Diagnostics (OBD)
No new posts Is This BMW 3 Series Too Expensive? Diesel Engine Technology
No new posts Oil Temperature Limits in Summer Heat Diesel Engine Technology
No new posts Part number for these cable holders Diesel Engine Technology
