Aliendrummer wrote: |
| Are there any "trouble spots" with the Polo 9N that might simply be clogged??? |
Hmm, there's a problem description from VW stating that the footwell can flood during heavy rain.
Solution: Seal the holes next to the hood hinges.
Unfortunately, I don't think your problem is related to that.
"However, please check the body control module (the "smart" central electrical system with many wiring harness connectors located under the steering column) for loose connectors and moisture. This module controls the windshield wipers in the 9N."
