Engine Misfire & High Idle Speed
Schneemann
Avatar-Schneemann
Post12-03-2006, 22:27    Subject: Engine Misfire & High Idle Speed Quote
After searching extensively but not finding what I need, I unfortunately have to post my problem here.
My 1Z is running really well, but:
The idle speed is usually slightly elevated, sometimes up to around 1100 RPM, and very, very rarely it's close to the correct value. This is regardless of whether the engine is warm or cold.
And there's a noticeable jerkiness during acceleration (both with the pedal and using GRA) below 2000 RPM.
When I shift into neutral while driving, the engine sputters for a few seconds and then suddenly runs smoothly at its (increased) idle speed.
And it slows down relatively slowly from a high RPM, and the speedometer needle sometimes jitters.
I don't know how else to describe it.
If anyone has a tip, I would be grateful.
Good night.
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 25-09-2026, 16:03.
Herr Antje
Post13-03-2006, 10:54    Subject: Engine Misfire & High Idle Speed Quote
Is the fault memory clear? Are the temperature sensor readings from the engine control unit within a reasonable range?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 25-09-2026, 16:05.
Schneemann
Avatar-Schneemann
Post13-03-2006, 17:42    Subject: Engine Misfire & High Idle Speed Quote
The error memory is clear, and the temperature sensor seems to be reading correctly according to my VAG-COM diagnosis, however, the temperature gauge in the instrument cluster is not rising properly.
Gruß Schneemann
No new posts Document: Increased Oil Consumption, AGP and AQM Engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Idle Issue: High RPM at 1.4 AMF Diesel Engine Technology
No new posts Golf 4, high idle speed Gasoline Engine Technology
No new posts Jerky idling Diesel Engine Technology
No new posts A6 2.5 TDI: Misfire & Rough Idle Diesel Engine Technology
