Door lock problem: Clicking sound, won't latch
flightmaster
Post15-04-2006, 21:31    Subject: Door lock problem: Clicking sound, won't latch Quote
Hello everyone,
I'm having a huge problem with the driver's side door lock.
In 9 out of 10 cases, the following happens:
Whether using the key fob or the key in the lock, the sound of the door lock engaging is only heard once. The indicator light confirming the locking doesn't flash, but the LED on the door handle does. If I repeatedly press the 'lock' button on the key fob, the lock eventually engages. The double locking mechanism is then activated, and the alarm system also functions.
Unfortunately, it's no longer possible to operate the FH (firearm) using the key.
WHAT COULD THAT BE???
The search function didn't produce satisfactory results...
Translated on 25-09-2026, 20:57.
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post16-04-2006, 21:12    Subject: Door lock problem: Clicking sound, won't latch Quote
What kind of vehicle is it?
Translated on 25-09-2026, 20:58.
flightmaster
Post16-04-2006, 23:37    Subject: Door lock problem: Clicking sound, won't latch Quote
Sorry.
It's a Volkswagen Golf 4, a 3-door model, and it's the Highline trim level.
By the way, I only realized through this problem that the car has an alarm system.
If the door closes twice and the hazard lights flash once, the car cannot be unlocked from the inside. If you try to unlock it from the inside (by pulling the interior door handle), the alarm system will activate.
That is probably the desired state.
Currently, the door usually only clicks shut once, allowing you to unlock the car from the inside without triggering the alarm system.
Are the microswitches in the lock the problem? Or is it more likely a control unit?
Translated on 25-09-2026, 20:59.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW TDI Turbo Whistles: Troubleshooting Guide Diesel Engine Technology
No new posts Automatic ZV Lock: Hands-Free Operation Transmission, Chassis, Body & Interior
No new posts ARL Issues: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts A3 AI cannot be properly encoded Gasoline Engine Technology
