Steffarn wrote: |
So, I only adjust the tracking constant when the car pulls to the left or right when driving over bumps. This is useful when the car is either compressing or rebounding.
The track changes more on one side than on the other.
"Or when braking hard, and even if it's not related to the brakes. When driving over bumps, the vehicle can also pull to one side even if the tracking is correct. However, if it consistently pulls in the same direction, this method is quite reliable."
I thought that a "normal" measurement with a specific setting would also change the track constant, but it shouldn't actually do that... (?)
I had my car aligned recently because I bought new tires and wanted to be on the safe side (it sometimes pulled to one side when braking). The alignment was slightly off, even though nothing had been changed on the suspension.
I also had the safety features adjusted, including the track constant, but I'm also a hypochondriac
